AC Clutch Problems
Old Aug 11, 2021 | 05:34 PM
xcrsp440's Avatar
xcrsp440
What causes such a big change in this gap?
Old Aug 11, 2021 | 06:30 PM
TooManyToys.'s Avatar
TooManyToys.
The friction material disc wears down over time, and when it starts to slip, the wear rate is even higher. Most of us catch this with the characteristics the OP mentioned, works at start and less when the load is higher, or variations in output over the drive cycle. While it's dependent on A/C use and freon charge, often it's best to check the gap at some interval, 50k, 100k, whatever it takes. If you catch it when it gets close to the max, often you can prevent excessive wear and a new clutch disc. I think I adjusted mine at 200k.
Edit. https://www.ford-trucks.com/forums/1...l#post16462426
cabn4me
Aug 12, 2012 08:26 AM
jonathonjeremiah
Jul 26, 2011 06:28 AM
ford351c
Jul 4, 2006 12:54 PM
Pocketchange5
1997 - 2003 F150
Sep 23, 2005 07:54 AM
Joe98684
Jul 6, 2005 11:10 AM
