Exhaust brake light flashing
Old Aug 8, 2021 | 02:36 PM
cj45lc's Avatar
cj45lc
Like title says when I push the exhaust brake button the light on dash blinks 3 or 4 times & goes out.
No codes showing
Thoughts ?
2016 in sig
Old Aug 9, 2021 | 10:18 AM
HRTKD's Avatar
HRTKD
Problem with the turbo maybe?
Old Aug 9, 2021 | 01:25 PM
cj45lc's Avatar
cj45lc
I don't know but I'm getting boost from the turbo like normal.
I've only read about this blinking deal on one other truck but his just went away on it's own after a day or 2 according to the post I read.
Old Aug 9, 2021 | 05:52 PM
Desert Don's Avatar
Desert Don
My ‘15 did the same to me one time. Heading west through Montana on I-90 pulling my 18K GVW Raptor. I had just pulled Bozeman Pass, stopped on top to take the dogs out for a pee break, letting the truck Idle. Started down the other side and no E-brake, light would just flash as described.
On my next fuel stop I shut the engine off and when I re-started all was back to “normal”. I put normal in quotes, because I don’t think that truck had a normal and FoMoCo never did figure it out while I owned it.
Old Aug 10, 2021 | 07:42 AM
cj45lc's Avatar
cj45lc
Thanks Don, that is pretty much what the post I read about happened with that truck but no luck with mine, I've restarted several times & still have the problem.
Old Aug 10, 2021 | 07:52 AM
Desert Don's Avatar
Desert Don
OK. That truck had multiple electronic issues and after 1 year went away. But the blinking EB light never did return. On that particular trip, which was actually its maiden voyage, when I got to my destination in AZ I took it in to Ford and left it for a couple days. They told me it had a couple of “latent codes” (whatever that means) but could find nothing wrong. They couldn’t tell me what the “latent codes” were, or what they meant! Hmmmm??????
Old Aug 11, 2021 | 04:01 AM
94ruck's Avatar
94ruck
My truck was doing that after I blew off the CAC hose. the hose clamp flew across the front of the engine and clipped the air sensor connection just after the air breather. just enough to wiggle it loose and break the safety clip. i unfastened and refastened that connection and cleared the code using torque pro and drove it another 700 miles with no issue. this literally happened last Thursday while pulling my Jeep to Hot Springs from fort worth.
Old Aug 24, 2021 | 07:19 PM
cj45lc's Avatar
cj45lc
Ended up having to reset with IDS & it's back working as it should
Old Aug 24, 2021 | 09:35 PM
Just Strokin's Avatar
Just Strokin
Probably a stored code in the PCM/ECU. Similar for the remote start will not work if any DTC's stored.
93-331-29PSI
6.7L Power Stroke Diesel
17
Jun 25, 2021 08:16 AM
alod3794
Aug 31, 2020 09:40 AM
mcali2
Jul 17, 2019 09:03 AM
BFTUFF
1997 - 2003 F150
Jul 5, 2012 09:34 PM
flagator
Feb 19, 2005 08:56 AM
