Software to determine Bad Injectors
Old Aug 8, 2021 | 11:14 AM
hank89's Avatar
hank89
I am the original owner of a 06' F250 6.0 w/ 225k miles on it. Has all the original injectors and I think I have some that are bad. I have scanguage2 and not showing any codes.
Will the Torque Pro App tell you what injectors are bad? Should I get Autoenginuity? Is there any software out there that does injector contribution test other that the Ford Software?
What about the method in this video where you disconnect all the injectors and the turn the key on with one plugged in at a time?
Sorry, I am a bit out of touch with the latest on the 6.0...Mine has been running great for years and I haven't been on this forum in a while.
Thanks,
Hank
Old Aug 8, 2021 | 02:00 PM
Motohead911's Avatar
Motohead911
Hi Hank,
Forscan would be even better than Torque Pro. Probably even better than AE. But none of them truly do an uncompensated balance test, which is what is needed. There are some high end scan tools that will do it, but I couldn't tell you which ones. One other option is a VCM clone of one sort or another. Some work well and others not so.much. I have used a Ford SVCI j2534 device with success. But sometimes it take a little work. The last option would be to goto the dealer and have them run a diagnostic test.
Old Aug 8, 2021 | 03:55 PM
Yahiko's Avatar
Yahiko
Having sold a few of the clone VCM units I have found they are not all created equal. (some are good and some are junk)
That said I am no longer selling them and my agent that I was working with has moved on. I
am not going to be looking for a new agent.
All that said you should avoid the Autoenginuity. It has an issue with the uncompensated tests.
It will tell you all is good even with an almost dead injector.
As
@Motohead911 said above Forscan is a good low cost option. You want the laptop version
as it will do more tests and have options that the smart phone and tablet versions don't have.
I believe the reason it they feel that with the phone you would be driving and the laptop software
you would be in a shop of garage doing the work.
Old Aug 8, 2021 | 04:51 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
With that many miles on stock injectors it isn't worth testing. I'd just replace them or $250 and we can tell you how bad they are before replacing. I don't recall a time that anyone has sent in injectors, HEUI or common rail that actually passed.
Old Aug 9, 2021 | 12:16 PM
hank89's Avatar
hank89
Thanks for all of the help! Im going to try Forscan out!
Hank
Mikethezipper
Apr 30, 2020 10:34 PM
tpc3
Dec 13, 2013 08:36 PM
Roasted7
Sep 27, 2012 11:18 AM
desertt5
Sep 28, 2009 05:45 PM
