Yoke identification?
Old Aug 1, 2021 | 09:58 PM
Kyle Oolman's Avatar
Kyle Oolman
I have a 97 f250hd 4x4. I snaped my yoke off on the rear end. I'm having troubles trying to figure out the correct one to buy. There seems to be a few different ways to label them. I've seen 10.25 and 10.5. Plus is there any upgrade ones that won't snap with the torque I have?
Old Aug 1, 2021 | 10:13 PM
Edgethis's Avatar
Edgethis
You have the long pinion. 92 ish and older used a shorter pinion and yoke. Just rebuilt my rear end a few months back and went with this Yukon yoke.
Old Aug 1, 2021 | 11:21 PM
Kyle Oolman
It dosent have anything to do with rear gears or spline count?
Old Aug 2, 2021 | 05:55 AM
Edgethis's Avatar
Edgethis
No, the only real difference was 92 and earlier had a shorter splined portion on the pinion and a different yoke to accommodate that. 93 ish and up have the "long" spline. More splined contact area between the yoke and pinion which is stronger.
10.25 and 10.5 gears are pretty much the same except for a pinion bearing inside housing.
GNR22
Jun 19, 2012 04:43 PM
bearhugger
Apr 6, 2009 08:34 PM
rocket_shelley
1997 - 2003 F150
Oct 13, 2004 01:58 AM
hoxiii
Feb 24, 2004 04:18 PM
