Sponsored by: Real Truck
Defrost only
Old Aug 1, 2021 | 11:10 AM
264WSM's Avatar
264WSM
Defrost only
Noticed that I am getting defrost only for my air supply. I even switched it to heat and it came out at the windshield. Where is the first place I should look?
2000 F-350
Old Aug 1, 2021 | 09:08 PM
Parabolst's Avatar
Parabolst
Pulse Vacuum modulator Dorman Part #600-402 located on the passenger side fender of engine bay. When it fails you loose auto locking 4wd hubs and your air system defaults to defrost for safety in winter situations.
Old Aug 1, 2021 | 09:15 PM
Parabolst's Avatar
Parabolst
2000 F-350
It could be wiring to the pulse modulator, vacuum lines or modulator itself.
The ugly thing with the plug on top of it next to the negative battery terminal.
Old Aug 2, 2021 | 05:43 AM
projectSHO89's Avatar
projectSHO89
It's a loss of vacuum supply to the HVAC control head.
Inspect the vacuum line that runs through the firewall to ensure it is not disconnected or damaged.
A cracked/leaking PVH solenoid body is only one of the potential causes. Cap off the supply to the solenoid and see if your vacuum-powered HVAC functions return or not.
Old Aug 3, 2021 | 11:00 AM
05SuperDuty250's Avatar
05SuperDuty250
Having the same issue on my 05 F250. Where do the vacuum lines come in through the firewall?
Old Aug 3, 2021 | 02:06 PM
FiveOJester's Avatar
FiveOJester
The HVAC defaults to defrost so you've likely got no vacuum, or not enough vacuum to move the actuator. I would do the following (in this order):
-Verify vacuum pump is working.
-Verify the vacuum pump cycles off after 20-30 seconds. If it doesn't you've got a vacuum leak somewhere which will require some investigation to find
-If all of that checks out then you'll want to look at the actuator under the dash.
My money would be a vacuum leak somewhere. The 4x4 solenoids are a common item. In the photo above, it's the item next to the fender with a white top. The vacuum pump is the black item to the right of the 4x4 solenoid. The vacuum reservoir is the tank between the vacuum pump & battery.
Spend the $30-40 for a hand vacuum pump. This is very helpful in troubleshooting vacuum leaks.
Old Aug 6, 2021 | 09:13 AM
264WSM's Avatar
264WSM
I switched to manual hubs about 3 years ago. Could this be causing a problem?
Old Aug 6, 2021 | 05:23 PM
projectSHO89
Did you do ANYTHING that I and others previously advised you to check?
This stuff ain't rocket science but you do have to follow directions....
Old Aug 7, 2021 | 10:09 AM
264WSM's Avatar
264WSM
I've been on the road since the original post - sux being a truck driver - time kinda stands still when you're away from home.
Old Aug 7, 2021 | 11:15 AM
projectSHO89
Yeah, it sux.
But, do the stuff that is recommended before wasting everyone's time with other stuff.
The internet will still be here when you get around to checking it.
Old Aug 26, 2021 | 09:31 PM
264WSM's Avatar
264WSM
Drove it a distance today and noticed I had no cruise control either. Popped the hood and found a rodent nest on top of the Vacuum solenoid. Good place to start!! I'm not going to troubleshoot that mess. I'll make sure the pump is working, then replace the hoses and solenoid.
If I drove the truck more, you'd think I could keep the pests out of it!! Even my cat is on welfare and is too lazy to work!
Huettl
Sep 7, 2016 11:58 AM
xxkenny90xx
1978 - 1996 Big Bronco
Jan 28, 2016 03:07 PM
Shovelhead 93
2004 - 2008 F150
20
Sep 16, 2012 10:17 AM
tk1251k
Aerostar
Jan 22, 2007 06:47 PM
