Aerostar Ford Aerostar
not much heat
Old Jan 20, 2007 | 06:18 AM
tk1251k's Avatar
tk1251k
not much heat
New radiator thermostat back flushed system. Not much heat front vents slightly more rear vents. 1990 aerostar 3.0.Read alot about blend door opening and closing. I do not hear anything when adjusting from vent to heat. Another question is when blower placed on should center vent blow air mine does not. thanks terry
Old Jan 20, 2007 | 08:29 AM
tom_foreman's Avatar
tom_foreman
Where the air comes out depends on the lever setting.
Heat - blows at your feet
Vent - blows out the vents in the dash
Defrost - blows on the windshield
mix - blows both at your feet and the windshield
A/C - blows out the vents in the dash
Max (A/C)- blows out the vents in the dash with fresh air opening closed.
The blend door is controled by the temperature selector. You have have hot, warm, or cold air depending on where you put this.
So, is the problem that the air is not hot or that you don't get much air?
Also, Vent, AC, and MAC (A/C) should cause the air to come out the top vents in the back while Heat, Defrost, and Mix should cause heated air to come out the floor vent in the back.
I hope this helps.
Old Jan 20, 2007 | 10:08 AM
tk1251k's Avatar
tk1251k
Front air at feet is alittle warm while setting is on heat and control is as far to hot as it goes. Heat rear vent floor is hot. terry thanks
Old Jan 20, 2007 | 12:40 PM
ken1mod's Avatar
ken1mod
My heater core clogged up, back flushing helped a lot.
Ken
Old Jan 20, 2007 | 02:22 PM
tk1251k's Avatar
tk1251k
IS tere anyway to check blend door wihout taking off most of dash and are there ant check valves in vacuum lines I coul check. terry
Old Jan 20, 2007 | 02:23 PM
tom_foreman
Could be a plugged heater core like Ken said. Or you may need to adjust the blend door cable. You have to raise the top of the dashboard to get to the cable.
Will the temp lever move all the way in the cold direction? If not look at the cable.
Old Jan 20, 2007 | 02:31 PM
tom_foreman
The temp control lever uses a cable not a vacuum line. Check valve will not affect the temperature.
You don't have to take off most of the dash. If I remember correctly you remove the cover/hood that is over the instrument panel. Then remove a few screws (some of which are a bear as they are near the windshield). Then lift up the panel to expose the cable and mechanism.
Move the cable back and forth to see if you get free/full movement of the door.
Old Jan 20, 2007 | 02:36 PM
tk1251k's Avatar
tk1251k
Thanks I ll give that a try not too bad cold and I still have rear heat. So as I understand the blend door operated by cable. thanks terry
Old Jan 20, 2007 | 02:38 PM
tk1251k's Avatar
tk1251k
Forgot to mention that cold lever does go all the way down. terry
Old Jan 22, 2007 | 12:41 AM
Bear River's Avatar
Bear River
Former ******
So is it that the air is not hot, or that the air is not coming out the vents?
Old Jan 22, 2007 | 06:47 PM
tk1251k's Avatar
tk1251k
Air comes out rear vent and front floor vent but rear vent is only hot front cold or lukewarm at best.terry
WoodBoss
Mar 9, 2015 07:53 PM
F-250 restorer
Apr 7, 2014 08:30 PM
ttles714
Dec 19, 2013 06:30 PM
AlM
1978 - 1996 Big Bronco
Dec 10, 2010 08:14 PM
armybronco2
Bronco II
May 17, 2008 05:59 PM
