MSD 6A/6AL IGNITION CONTROL
Old Aug 2, 2021 | 05:03 PM
SFaulken's Avatar
SFaulken
Are you sure that you've got the Engine at TDC, and not 180 out?, are you sure the firing order is correct, and yes, I personally would remove the vacuum advance, when doing initial startup.
Old Aug 2, 2021 | 05:09 PM
vaellene's Avatar
vaellene
so i put in stopper rotate clockwise till it stops, mark balancer rotate other way till it stops mark balancer than mark center of them two marks = TDC?
This is how ive read it to be done
Old Aug 2, 2021 | 06:24 PM
SFaulken's Avatar
SFaulken
Are Both the intake and exhaust valves closed on #1, where you've marked the balancer?
Old Aug 2, 2021 | 06:30 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by vaellene
f250 460 7.5
What year?
Old Aug 2, 2021 | 06:51 PM
FuzzFace2's Avatar
FuzzFace2
Are you still trying the MSD box and if so is it a 6A or a 6AL?
If it is a 6AL do you have a RPM limit chip installed?
I cant remember what happens if you don't have one installed but me thinks it will not run as it has no way to limit the MAX RPM.
Dave ----
Old Aug 2, 2021 | 07:44 PM
vaellene's Avatar
vaellene
1987 f250...
F-250 restorer
Jun 30, 2017 10:06 AM
xdroogx
Mar 12, 2010 12:45 AM
RP27G8G
Mar 11, 2006 12:11 AM
