power window switch bezel?
Old Aug 2, 2021 | 06:10 PM
nissen4's Avatar
nissen4
so the shipping tape isn't the best way to secure this, but the plastic attachment points all broke off. the part that holds the speed nut is completely gone, as is the slot for the friction tab. any ideas how to repair this without replacing the door panel?
Old Aug 2, 2021 | 06:56 PM
wwhite's Avatar
wwhite
I haven't looked, but I also need the bezel replaced.
Old Aug 2, 2021 | 07:21 PM
EllieMae94's Avatar
EllieMae94
I got these from OBS Solutions:
https://obssolutions.net/collections...37408029180098
https://obssolutions.net/collections...37408029442242
Old Aug 2, 2021 | 08:24 PM
nissen4's Avatar
nissen4
That's a great solution! Thanks!
Old Aug 3, 2021 | 01:04 AM
TexasGuy001's Avatar
TexasGuy001
The OBS Solutions repair kit is pretty nice. It is a little tricky to install. Test fit several times with the bezel in place before drilling the holes for the aluminum plates. Also, I had to use a dremel to remove a little of the broken areas.
https://www.ford-trucks.com/forums/1...with-pics.html
Olds64
Jul 21, 2023 01:16 PM
Dan5993
Sep 2, 2021 09:37 AM
wnc05ford51K
Escape & Escape Hybrid
May 25, 2019 07:22 AM
TnBuckeye
May 28, 2016 07:53 AM
kyfx4
2004 - 2008 F150
Jan 13, 2008 02:56 PM
