Trailer battery charge circuit behavior?
so - the catch - my horse trailer has a variety of accessory lights that run off of this circuit, but it does not have its own battery. with my prior trucks this has been fine because there is just a constant 12v+ on the black wire from the 7 pin harness. Does the Ford system anticipate the trailer having its own battery, and only supply charging voltage if it detects a battery? Can anyone tell me anything else that would be illuminating?
I’m prepared to add a battery to the trailer but would like some confidence the issue is related….
thanks! Pics because every thread needs pics…
This is so dumb,,,,,, futher testing says the door can be open, but a foot on the brake and it will charge too. Also,,,, if you put it in neutral, you can take your foot off the brake, WITH the door open, and it continues to charge. So,,,,, it's safer to be in neutral, with your door open, than it is to be in park, keyfob in your pocket, while you are hooking up the trailer? And to top that off,,,, you can be in neutral, get out of the truck, with the door open, and the keyfob in your pocket, and it charges,,, but if you are in park,, it shuts off the charging with any of those things. Makes perfect sense right?
Passenger door doesn't change anything. I think the thought here is if you get out of your truck to hook up a trailer, it turns off charging so there are no sparks as you plug it in since your fob will be in your pocket. When you get back in, it will turn on charging. If you have an electric jack that needs power, you just need to leave your fob in the truck and shut your door.
Mine works without battery. I was able operate all the lights and slides on my travel trailer with no batteries installed. Just the 7-way on the truck.
