Cam gear Question
Old Jul 27, 2021 | 11:35 PM
jernigan's Avatar
jernigan
Cam gear Question
I have a 1990 F150 5.0, I have a 99 explorer 5.0 in the truck now just about ready to start it and got to thinking. Did I need to change the gear on the cam to a steel gear? Or will the gear on my 1990 distributor be ok with the roller cam?
Old Jul 28, 2021 | 06:19 AM
timbersteel's Avatar
timbersteel
The 1990 5.0 would have been a flat tappet that used a cast iron cam gear. The Explorer cam is roller that used a steel cam gear.
Good job checking before starting it. The cam gear on the distributor would be chewed away in short time. Once you swap it, you should be ok.
Steel on roller, cast iron on tappet.
Old Jul 28, 2021 | 04:31 PM
Mikulh's Avatar
Mikulh
Yes. You need a steel distributor gear to be compatible with the roller cam.
Old Jul 28, 2021 | 07:05 PM
jernigan's Avatar
jernigan
Does anyone know what year the F150s went with a roller block? I thought around 94 needing to know so I can order a drive gear for my distributor, I need it to fit on my 90 model distributor.
Old Jul 28, 2021 | 07:50 PM
Zrt1200's Avatar
Zrt1200
My 94 351w is a roller cam block F4TE. As for distributor gear you will need to know the OD of the distributor shaft. See the OD sizes on the Summit link....
​​​​​​https://www.summitracing.com/search/...ibutor%20gears
Old Jul 28, 2021 | 09:35 PM
Scndsin's Avatar
Scndsin
If you have the original distributorless drive from the explorer, take the gear off it & put it on your original. Looks like headless distributor.
Old Jul 28, 2021 | 09:57 PM
jernigan's Avatar
jernigan
Wish I still had the explorer stuff threw it all out a few months ago.
Old Jul 28, 2021 | 10:18 PM
jernigan's Avatar
jernigan
Just ordered one from summit thanks for the link. I measured .534 the nearest one on the website was .531 could just be my measurement though.
Dutchbuilder
Jun 27, 2015 09:52 PM
highboy1975
Mar 24, 2009 08:39 PM
crash12884
Aug 17, 2007 02:19 PM
guinness2199
Mar 15, 2006 07:38 PM
Jake
Feb 15, 2005 10:04 PM
