uhhh distributor question??
Old Aug 13, 2007 | 03:29 PM
crash12884's Avatar
crash12884
I have an 82 f150 with a 302 4x4 and my distributor isnt working correctly... the vacum advance is all messed up and in looking for a new 1 i ran into a problem... they say there is 2 diff distributors for my engine either steel or cast iron gear and they say they arn't interchangable... i kno sometimes they dont kno what they are talking about at the part stores but this i have no clue about either... how can I tell which I need or does it matter?
Old Aug 13, 2007 | 04:09 PM
Phillip Guidry's Avatar
Phillip Guidry
the difference is for the type of material the gear on the cam is made of........ i could be wrong, but, stock non roller cam needs cast dist. gear and roller cam needs steel dist. gear or vice versa ?
Old Aug 13, 2007 | 08:38 PM
mvvette97's Avatar
mvvette97
Yes, the roller cam has to have the steel gear. I had to change that when i put the newer roller 302 in my 84. Yours would not have the roller cam so you would need the cast gear.
Old Aug 14, 2007 | 04:41 PM
crash12884's Avatar
crash12884
thanks guys! atleast I learned something new!
Old Aug 17, 2007 | 02:19 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
