distributor question
Old Mar 23, 2009 | 07:07 PM
highboy1975's Avatar
highboy1975
what type of gear should i get to restab the distributor? i put a comp cam in it, and the choices are iron, steel, or bronze. i ordered the steel gear but somehow feel i did the wrong thing, but i still have time to cancel. also, how do i go about stabbing this thing so that it will be right?
Old Mar 24, 2009 | 07:16 AM
Barry_R's Avatar
Barry_R
The gear needs to match the cam.
A standard or performance cast cam will use an iron gear - that takes care of about 90% of the FE engines out there.
A bronze gear is only used with a steel roller cam. Race car stuff - you'd probably know if you needed one of those.
Steel gears are an alternative for certain roller cam cores. They were made by/for Crane. Since Crane is closed they are something of a non-issue right now.
Old Mar 24, 2009 | 08:39 PM
highboy1975
gotcha thanks
jrockdiddy
May 11, 2015 09:39 PM
BKM-WR3
Apr 14, 2015 05:26 PM
wadar1969
32
Nov 8, 2014 09:41 AM
lmadore
Oct 25, 2005 07:53 AM
Racerdave
Apr 2, 2003 01:07 PM
