P1832
Old Jul 27, 2021 | 03:20 PM
Listor's Avatar
Listor
P1832
Ok got my OD button all rewired not near as much fun as you would think!
P1832Description The Transmission Control Module (TCM) monitors the Transmission Transfer Case Differential Lock-Up Solenoid. The TCM sets the OBDII code when the Transmission Transfer Case Differential Lock-Up Solenoid is not to factory specifications.
Time to dig into this one
Any suggestions ??
Old Jul 27, 2021 | 04:39 PM
BWST's Avatar
BWST
Got Data?
How is the transfer case shifting for you? Does it have problems shifing into 4Hi or 4Low? Or problems shifting from 4hi/4Lo back to 2Hi?
These codes can sometimes occur occasionally and not be an issue. I think it might happen when a shift hangs for a bit, or something like that.
If you do not have problems getting into and out of those ranges, I would just run it.
Old Jul 27, 2021 | 05:19 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am not finding P1832 in the Ford Service Manual, but I have been outside working all day, so I could just be overlooking it...
While doing a search for it here on the FTE, there seems to be a bit of history concerning this DTC. Some resulted in nothing being wrong, where others lead to an issue and a resolution.
Search results link: https://www.ford-trucks.com/forums/s...rchid=31787416
Old Jul 27, 2021 | 05:30 PM
Sous's Avatar
Sous
FTE Emeritus
OK, I took a different route and referred to a PDF version of the Ford Service Manual I have on file.
and
Which led me to a section 308-07A and this...
I have attached the pinpoint tests which includes Pinpoint Test G associated with the P1832 DTC.
All of this is irrelevant if your transfer case, 4x4 and OD button and light are functioning properly.
File Type: pdf
Old Jul 28, 2021 | 06:08 AM
Listor's Avatar
Listor
so i pulled the brush plate , checked harnesses , pulled connections , everything seems to be in tact, I can feel it go into 4low, but nothing in 4 high, i will mess with it more today!
Old Jul 28, 2021 | 06:09 AM
Listor's Avatar
Listor
and
Thanks Sous, that's what i was hoping for!
bullit340
Dec 7, 2021 10:04 PM
Powerstroke1995
Sep 11, 2007 04:09 PM
Benny2002
Aug 14, 2007 12:03 AM
Benny2002
Jul 24, 2007 06:22 PM
TPLynch
Aerostar
Jul 19, 2006 07:59 AM
