351 M /400 timing
Old Jul 22, 2021 | 10:13 PM
Mechanicmanjjkk's Avatar
Mechanicmanjjkk
351 M /400 timing
So I have elected myself to help a friend with his 1977 F100 351M conversion , I checked TDC on balancer and electronic ignition Rotor points at 4:00 position distrutor cap where Number 1 spark plug wire starts firing order 13726548 counter clockwise , Engine bearly runs 1200 rpms then pops out of intake ,but if I turn carb clockwise until it binds on intake runs better at Idle and above 1800- WOT , timing mark is inch away from pointer before BTDC ,took around the block at feels Missing ,shut engine off and restarts runs fine in park ,
Old Jul 22, 2021 | 10:24 PM
351Cleveland C4's Avatar
351Cleveland C4
The balancer is marked in degrees. An inch is probably about 10 degrees?
It needs to be timed at 10-12 btc. If you can't get there because of obstructions then you need to pull the distributor and move it a tooth or two.
Old Jul 22, 2021 | 10:51 PM
440 sixpack's Avatar
440 sixpack
That's correct. or you can move the plug wires one hole.
Old Jul 22, 2021 | 10:55 PM
Mechanicmanjjkk
So My friend has number 1 Spark plug wire below the 1 marked on the cap at 4 or 5 cloak position location on Cap ,I read about something that I can change the starting point on Dizzy Cap verses pulling the distributor and rotating couple notches ,What do you think , my other question is ? Is Number 1 normally at 1:00 position on cap standing at front engine looking down the middle of engine .
Old Jul 22, 2021 | 11:01 PM
351Cleveland C4
Ok, backup.
You're talking about way too many positions and wires and clocks.
It doesn't matter
The firing order needs to be correct, and the rotor needs to correspond. That's it.
You can move the wires over and Re-clock the distributor body, but that's a pretty big adjustment.
Old Jul 22, 2021 | 11:37 PM
440 sixpack
probably 1 hole would do it. but as 351 said it doesn't matter.
The #1 spot on the cap is just the normal place to start. it makes no difference though.
Old Jul 23, 2021 | 11:44 AM
5851a's Avatar
5851a
https://th.bing.com/th/id/R.895e4f89...sl=&pid=ImgRaw If you look at the part number 12127 on the side, put the rotor aligned with the first number 1. That should be plug number on cap. If you look at the casting right above the O ring where the seat area is there will be a chisel mark and a corresponding chisel mark on the engine block. If you line all that up you timing should end up within a degree or 2 of factory spec. That is assuming timing chain not off a tooth and distributor in good operating condition.
Old Jul 26, 2021 | 04:35 PM
Mechanicmanjjkk
Thanks for the suggestions I was able to change firing order move the #1 spark plug wire to #8 position and start the firing order ,But I did use the idea of inch is 10 degrees well done
Old Jul 26, 2021 | 04:37 PM
Mechanicmanjjkk
Thanks for your Knowledge and wisdom
Old Jul 26, 2021 | 04:43 PM
Mechanicmanjjkk
Looks like the pervious mechanic or owner screwed up when he was replacing spark plug wires ,He or They position number #1 on wrong terminal of the Dizzy Cap ,after moving over to #8 and installing number one everything fell into place vacuum Kan pointing down the middle of the block job well done
400mullins
Feb 17, 2011 03:20 PM
78Ranger400
Nov 5, 2010 06:22 PM
350ford4x4
Jul 21, 2006 06:43 PM
73Galaxie
Jun 17, 2005 01:15 AM
higeonsb
Aug 12, 2003 04:30 PM
