1978 351m/400 missing timing pointer
Old Nov 5, 2010 | 12:25 PM
78Ranger400's Avatar
78Ranger400
Could someone take a picture or give me a part number for the timing pointer for a 351m/400 Engine. Trying to set timing and have no reference mark to time too. . I guess the next step is to find TDC as best I can through the spark plug holes and guess from there. Any help would be much appreciated. Thanks
Old Nov 5, 2010 | 02:03 PM
704 dentside man's Avatar
704 dentside man
First off...the timing pointer hangs on a dowl on the lower left hand (as you're looking at it) face of the block...an gets bolted through the timing cover. It's kinda a rectangular looking thing with a triangulated shape perpendicular to it.
If you're bound and determined to find TDC, pull the number plug, and you can either disconnect the coil and bump the key until no more compressed air comes out...or...put a dowl or screw driver down the hole and manually turn it over at the crank until the screw driver is at the top. That'll be tdc.
However, if you don't have a pointer, but know you're relative close to being in time, twist the dizzy until the engine starts to ping, then back off.
Old Nov 5, 2010 | 03:32 PM
78Ranger400
Thanks, well sounds like the pointer is missing for sure...Do you set the timing with the vacuum advance line attached to the distributor or with it plugged.
Old Nov 5, 2010 | 03:44 PM
704 dentside man
^^^Plugged...I typically use a golf tee.
Old Nov 5, 2010 | 04:11 PM
wyckedcombo17's Avatar
wyckedcombo17
^Golf tees work great quite frankly
And are you sure its gone? Mine was pretty hard to find. If you're standing outside truck looking at the engine, it should be in about the 10-11 o'clock position. It might be caked with grease and be hiding so try spraying a lil bit of carb cleaner.
Old Nov 5, 2010 | 05:26 PM
78Ranger400
Yep its gone I can see the locating pin and the bolts exactly where you said to look. Does it make a difference where the other side of the vacuum line goes. I had it on the back of the carb, but didnt seem to be getting any vacuum at all, so I moved it to the vacuum tree on the back of the engine. Now I am afraid I am getting to much vacuum. On this engine apparently someone has tried to remove all the smog equipment, but I have no idea how the vacuum lines should be run now. Thanks again for everyones help.
Old Nov 5, 2010 | 06:22 PM
steponit's Avatar
steponit
Vacuum advance nipple can remain open .
The key is to plug the vacuum hose so it doesn't suck air.
Pointer D3AZ-6023-A
fordno1
Jun 14, 2025 12:24 PM
Odisvan
Jul 5, 2016 10:13 AM
mawagian
Oct 18, 2015 04:41 PM
clhart426
Jul 29, 2011 03:41 PM
78Ranger400
Apr 21, 2011 04:22 PM
