Ignition problems
Old Jul 16, 2003 | 04:28 PM
higeonsb's Avatar
higeonsb
Unhappy Ignition problems
I recently did a swap. I put a 400 from an 82 E250 2wd into my 78 F150, which had a 351M. I retained the 351 distributor in the 400. I also kept the carb from the 351. Problem is it does not run correctly. No power really ugly mileage. The timing is correct. when installed I put in a new timing chain and gears, plugs, pickup coil, coil, plug wires, cap and rotor. I have been told by parts dealers there is a differance between the ECUs and that there isn't. Help any suggestions?
Old Jul 16, 2003 | 04:44 PM
Mil1ion's Avatar
Mil1ion
Ignition problems
Welcome to FTE!
Please read this
https://www.ford-trucks.com/forums/s...hreadid=102632
If you still have the original dizzy in the newly re-built 400, it should work.
You need 3 things;
Air
Fuel
Spark at the correct time.
Are you sure the rotor is pointing at the proper spot ?
Have you tested the Ignition module ?
Old Jul 16, 2003 | 04:57 PM
higeonsb's Avatar
higeonsb
Air good
Fuel Good
Spark checked and it is OK.
Dstributor pointing in the correct direction. Out of the 351. But I do have the one from the 400.
Timing set at 3% BTDC For the 400 it could be from 12 to 3 and I have tried all of the above.
Tweeking the fuel mixture helps but very little.
Is there a difference in the Timing Chain and gears.
Old Jul 16, 2003 | 05:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Ignition problems
Blown power valve in the carb?
Strange parts dealers, don't they know there is no ECU on a 78???
We can hope that you have an aftermarket straight up timing set.
Old Jul 16, 2003 | 05:50 PM
Mil1ion's Avatar
Mil1ion
Ignition problems
Those dizzies are inter-changeable.
I think you're off with timing though.
Set it at 12* BTC with vacuum advance hose removed and plugged at 650 rpm
Have a look at the calibration codes and specs in the thread at the top of this forum, to figure your timng.
Old Jul 16, 2003 | 07:42 PM
neverenough's Avatar
neverenough
Ignition problems
Verified your plug wires to make sure they are all in the correct order? I would also put a vacuum gauge on the motor to make sure the carb is adjusted correctly and the motor is in good shape.
Old Aug 12, 2003 | 04:30 PM
Redone's Avatar
Redone
Ignition problems
I never saw that sticky and would like the information. Can someone help?
