Tachometer 88 F250
Old Jul 22, 2021 | 03:00 PM
rogersdan's Avatar
rogersdan
Tachometer 88 F250
Instructions from after market tach say attach green wire to negative side of coil. I have two wire coming from the negative side of the coil, can I connect to either wire?
Thanks, Dan
Old Jul 23, 2021 | 08:37 AM
jas88's Avatar
jas88
One of the wires goes to a noise suppressor, doesn't it?
Old Jul 23, 2021 | 09:08 AM
GNR22's Avatar
GNR22
Just throwing this out there, the wires for the tachometer are already present in your current gauge cluster wiring harness, even if you don't have a tach. I'd have to find a wiring diagram to find what color wire it is, but that will save you from running wires outside of the cab.
Old Jul 23, 2021 | 05:09 PM
rogersdan's Avatar
rogersdan
GNR22,
Thanks, I think I can locate a wiring diagram, I see that my fuse box has a tachometer listed in the #16 space, might be able to track it from there.
Dan
Hendrixx
13
Jan 18, 2010 05:54 PM
IcemanV8
Nov 5, 2007 06:30 AM
fastmover
Aug 3, 2007 12:07 AM
MineralStang
Electrical Systems/Wiring
Feb 27, 2005 07:47 PM
MonsterBroncoKid
1978 - 1996 Big Bronco
Aug 26, 2004 11:01 AM
