quick question 4R100 sensor locations between case variations
Old Jul 21, 2021 | 07:24 AM
monumentman's Avatar
monumentman
I am doing a 4x4 swap on my 2001 F250 with the V10. I have a donor trans (gas 4x4 from a 99)
on my 01 I have input and output sensors on the bellhousing
on the 99 4x4 trans there is a plastic plug on input side and nothing on output. I assume the output location would be on the transfer case?
My question is do I need the input sensor since my 01 has plug on harness for it and if so does the plug pull out to accept sensor?
Thanks
Old Jul 21, 2021 | 05:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The plug will pull out and the sensor will go in. The real question is if the '99 trans has the tone wheel inside the transmission that the sensor needs to read. If you don't have a functional input sensor you will have a transmission in limp mode all of the time.
Old Jul 21, 2021 | 08:00 PM
monumentman
thanks for the reply.
I looked into the plug hole and see a toothed wheel..didn't realize it was that easy
it should be fine correct?
Old Jul 21, 2021 | 08:38 PM
Mark Kovalsky
Yes, that should work fine.
bbf385
1983 - 2012 Ranger & B-Series
Apr 29, 2020 11:18 PM
Ian___F350
May 12, 2015 05:28 AM
Kingfisher591
Sep 26, 2012 08:58 PM
Midwest Dually
Mar 10, 2011 04:46 PM
