6r80 test port?
Old Jul 24, 2021 | 07:38 AM
meborder's Avatar
meborder
6r80 test port?
Does the 6r80 have a pressure test port? If so, where is it located?
looking for a way to install a trans temp gauge, but so far I’ve been unable to find anything resembling a test port as I’ve seen in the past.
any help is appreciated
Old Jul 24, 2021 | 09:27 AM
ford390gashog's Avatar
ford390gashog
No test port, the fluid temp is shown on the dash or can be brought up with a scanner.
Old Jul 24, 2021 | 09:36 AM
meborder's Avatar
meborder
Well that explains why I couldn’t find one. Thanks.
so it’s a 2014 expedition and there is no gauge for TFT in the dash.
if I get one of these:
https://www.bankspower.com/series-2-...l%3D5.4L%20GAS
will it be able to see the data from the PCM for TFT?
any thoughts?
Old Jul 24, 2021 | 03:39 PM
ford390gashog
Yes It would show, I will also say if you stay within capacity fluid temperature is a non issue. You can also spot check temps for a lot less cash using the Torque pro app and a elm327.
SoCalAngler
28
Jan 11, 2024 10:44 AM
Crn316
Aug 15, 2014 12:30 PM
CREECY Strokin It!
May 8, 2011 07:00 AM
