Noise from front when in reverse
Old Oct 31, 2003 | 10:47 AM
TBeck2000's Avatar
TBeck2000
Question Noise from front when in reverse
This question is for my dad's 1998 Ranger w/ 162k miles. It's a 4.0L 5-spd manual 4x4. He had been starting to have problems with noise coming from the drivers side front when he turns the wheel to the left and moves in reverse. There is no noise if the wheel is turned and he moves forward. He descibes the sound as a "gritty, grinding" sound. He said that he checked the brakes and there didn't seem to be any problems. He's planning on dropping the truck off at the shop next week, but was wondering if there was anything specific that could be the problem.
Thanks in advance.
Tim
Old Nov 1, 2003 | 05:50 AM
wolfen's Avatar
wolfen
Welcome to FTE TBeck2000,
Ask you dad if he has had the front bearings + hub/rotors retightened?
Sometimes a wheel hub/rotor can loosen just enough to have this "gritty, grinding" noise occur; rotor rubbing against brake pad when the tire is under pressure and being pushed or pulled!
________________________________________________
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
cbeer68
Oct 18, 2010 03:27 PM
rylos
General Diesel Discussion
Feb 17, 2010 11:26 AM
TimW
Jun 17, 2007 06:23 PM
worknon10s
Apr 7, 2007 06:19 PM
