Sponsored by: Real Truck
Bad Wheel Bearing
Old Oct 18, 2010 | 01:33 PM
cbeer68's Avatar
cbeer68
Bad Wheel Bearing
I have a 99 F250 SD 4x4 Diesel and have a loud grinding or some kind of sound comming from the front drivers side of the truck when turning to the left and sometimes sitting still with the truck in drive and my foot on the brake. I have replaced the sealed wheel bearing unit. The noise sounds like it could be comming from the brake hydro booster?? I went to a local Ford Diesel mechanic for his opinion and he agreed it sounded like the hydro booster but could not pin point the problem. Has anybody had this problem?
Old Oct 18, 2010 | 03:27 PM
bpounds's Avatar
bpounds
Your thread title is misleading, because it is obviously not the wheel bearing. You changed that already, and since it does it when sitting still, it is not any running gear, or 4WD lock, needle bearing, etc.
I would guess it is the power steering pump, rather than the booster. Simply because that is where the moving parts are found. A good shop should be able to pinpoint that.
1badton
Dec 31, 2022 12:56 PM
7U_D4
Large Truck
Jun 28, 2012 03:56 PM
78bigbronco
1978 - 1996 Big Bronco
Mar 16, 2004 06:16 PM
mudcat12
Feb 27, 2004 05:30 AM
