Rear end swap
Old Jul 17, 2021 | 03:36 PM
ken kirkland's Avatar
ken kirkland
Rear end swap
I have a 1996 f150 302 super cab and I want to swap rear ends to one with a lower gear I was wondering will a f250 rear axle bolt up to my truck without having to move any mounts or hangers.
Old Jul 17, 2021 | 03:53 PM
Edgethis's Avatar
Edgethis
Itll bolt right up, assuming the trucks are same bodystyle. The lug patrern will be different.
Old Jul 17, 2021 | 04:54 PM
Mudsport96's Avatar
Mudsport96
Also ujoint will probably be different, and driveshaft length may change.
Old Jul 18, 2021 | 09:53 AM
Conanski's Avatar
Conanski
You need an F150 8.8 axle, what gear does it have now? 3.55 was quite common should not be hard to find and would be a nice upgrade from 3.08.. if that is what you have. If you can't find a suitable axle a gear swap might just be the most cost effective option, and if you do that go with 3.73 or 4.10 depending on what you use the truck for.
Vinman713
Feb 13, 2019 11:15 AM
PGill
Sep 21, 2016 12:27 PM
derbyhunter5
Apr 13, 2015 02:37 PM
azzj97
Aug 18, 2010 02:16 PM
AlDixie
Mar 19, 2000 08:26 PM
