tech folder doc
Old Jul 12, 2021 | 06:56 PM
IHateCommieCars's Avatar
IHateCommieCars
tech folder doc
I don't recall seeing anything specific to this topic written before, and if so, it's not in the Tech folder that I noticed. Would be useful, but I'm not the one to write it.
Why, How, and What to Know About Monitoring LIve Data
Or something to that effect. How many times do we tell people that they need to monitor data? Over and over we explain. But even better, a tutorial on why you need to monitor, how to get hooked up/different options, which PIDS to monitor and why, and what to be on the lookout for, and what it means when you see certain data. It should note the importance of fuel pressure monitoring as well.
Wish I could do it.
Old Jul 12, 2021 | 08:18 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I gave it a shot awhile back. It ended up reading kinda like an advertisement for certain products. That wasn’t what I was going for and the info was a bit spotty also.
https://www.ford-trucks.com/forums/1...eral-info.html
Old Jul 12, 2021 | 09:20 PM
IHateCommieCars
Yes, you did. Great job. It is mostly about the products, and those change so it's kinda hard to keep updated. I thought of that when I wrote the first post. I didn't see much of the other parts. I forget who put the chart together with all the sensor values, but maybe that one this put together with a little bit of why you want it (lame factory gauges, etc.) and how to interpret it. And add it to the Tech Folder, Mods!
Old Jul 13, 2021 | 04:56 PM
bismic's Avatar
bismic
It is from another forum, but there is this:
https://www.powerstroke.org/threads/.../#post-3143192
Old Jul 14, 2021 | 07:20 AM
RetiredMarine's Avatar
RetiredMarine
This is my first diesel truck. Wish I would have bought one a long time ago. I pull a 30 foot race trailer (Frequently 1500 to 1600 miles) and with the gas truck I was only getting about 4 mpg. I am not familiar with all the acronyms for what I should monitor, so if anyone could post them it would be greatly appreciated.
Old Jul 14, 2021 | 07:29 AM
bismic's Avatar
bismic
Post #31 in the thread linked below:
https://www.ford-trucks.com/forums/8...l#post17205909
Old Jul 14, 2021 | 07:42 AM
IHateCommieCars
LOL, that'll teach you, jarhead. Now you need an algorithm to search all those acronyms. I thought there was some variance between data monitoring devices as well - maybe what Scangauge uses is different than TorquePro, etc.? Or, maybe how they display anyway? But I'm prolly wrong. What device are you using, marine?
Old Jul 14, 2021 | 08:02 AM
RetiredMarine
I have the SCT4 tuner but use torque pro to do my monitoring with because I can see more displays
Old Jul 14, 2021 | 08:56 AM
IHateCommieCars
OK, I use TP too. Important - if you haven't already, you need to go into Settings and download the Ford-specific PIDS. You'll then see them in the Add a Gauge list. When I got my first diesel, I only had a ScanGauge, and you had to choose which 4 PIDs to monitor because that's all the display you got. But with TP, you can have a lot of gauges. I set up a profile for my trucks and one for my car. I keep EOT, ECT, FICM main, FICM power (rather than battery voltage), fan speed, transmission temp, IPR, VGT and boost on my screens.
Old Jul 14, 2021 | 08:58 AM
IHateCommieCars
BTW, before Mark tells you, :-), it's real important to monitor fuel pressure as well, but that requires a mechanical gauge and fittings to connect to the fuel regulator. As your pump starts to fail, pressure can drop, but the truck still run, and burn up your injectors. If your passenger rear injectors go out, it's prolly pump related and others will go out soon too if you don't fix it.
Old Jul 14, 2021 | 09:07 AM
IHateCommieCars
mistaken post
Mr J 125
Aug 10, 2017 10:52 PM
BenardLenard
Jan 30, 2017 05:51 PM
davbeisner
Dec 19, 2012 06:07 PM
texastech_diesel
Aug 5, 2010 07:53 PM
