460 Intake Manifold Dimensions
Old Jul 11, 2021 | 11:59 AM
77highboy77's Avatar
77highboy77
Hi all, I have a 460 in a 77 F250 that I'm starting to work on after a long time sitting. It needs a cam and lifters and I'm also thinking about finally having some D0VE heads redone. However, there is something off about this engine and I'm trying to figure out if the incorrect machine work is in the intake, heads, or block. The intake sits so low on the intake ports that they almost don't seal, but at the same time, the gaps in the front and back of the intake are much larger than they should be. It's an Edelbrock Performer intake from the early 90's, when the engine was built. If anyone has the outside dimensions for a stock intake, or an Edelbrock, that would be a big help in figuring this out, I'm hoping the issue is with the manifold.
Old Jul 11, 2021 | 05:42 PM
mark a.'s Avatar
mark a.
There are no other Edelbrock manifolds that will bolt on a 385 series big block so you have the right one.
Old Jul 11, 2021 | 08:41 PM
77highboy77
Yep, definitely have the correct manifold. I'm hoping someone machined the mating surfaces on the intake for some reason, causing it to be just a little too narrow for the heads and causing the large gaps front and back. The other possibility is that they machined the intake surfaces of the heads and the top of the block. If that is what they did, then going to the D0VE heads will correct the port height, but will give me an even larger gap to the block.
Old Jul 12, 2021 | 07:54 PM
DaveMcLain's Avatar
DaveMcLain
If it sits really high then it is wider than it needs to be not narrower. If they machined the intake faces of the heads then the intake would sit lower and closer to the walls at the ends.
Old Jul 12, 2021 | 09:06 PM
77highboy77
That's where the issue is, it sits extremely low on the ports, but has huge gaps front and rear at the same time, much larger than cork or rubber gaskets would seal.
Old Jul 13, 2021 | 08:51 AM
DaveMcLain's Avatar
DaveMcLain
Post pictures.
Old Jul 13, 2021 | 10:02 AM
77highboy77
I'll try to get pictures when I can, though the truck is 3 hours away from me, so I can only get to it every once in a while (also making it difficult to get the details figured out).
Old Jul 13, 2021 | 10:20 AM
DaveMcLain's Avatar
DaveMcLain
Is it possible that you happen to have a 351M/400 style intake by mistake somehow?
I just measured a 400 block and it is 8.375 wide at the end wall; a 460 block is actually narrower @ about 8 inches.
Old Jul 13, 2021 | 10:24 AM
77highboy77
It shouldn't be. If I remember correctly it says "Performer 460" on the intake.
DrZoom
Ford Truck Parts for Sale
Apr 3, 2016 02:20 PM
mnkeeking
Apr 10, 2012 07:14 PM
ironhead86
Mar 6, 2009 05:48 PM
JOHNNEHUS
Jul 21, 2007 11:58 AM
powerfull
Sep 14, 2003 04:41 PM
