Death wobble
Old Sep 30, 2021 | 06:42 PM
  #31
JDski's Avatar
JDski
This video should be watched by all with death wobble.
https://swisscows.com/video/watch?id...20wobble%20fix
The above link gives a good explanation of the causes of Death Wobble. Mainly it is about castor . However, it is a steering system and other parts can be involved There are castor shims available or a part from BD diesel that is a more involved to install.
Old Sep 30, 2021 | 06:49 PM
  #32
gersus's Avatar
gersus
After this many years why is this still a thing?!
Old Sep 30, 2021 | 11:13 PM
  #33
Norcalpr's Avatar
Norcalpr
it's not a Ford thing, it can happen to ANY solid axle vehicle...
Death wobble is not caused by a bad steering stabilizer. A steering stabilizer is a band aid to the problem, and its simply a way of Ford masking the problem for as cheaply as possible, to get you thru a warranty. A stiffer stabilizer is just like if you held the steering wheel tighter. Ever been able to stop death wobble by holding on tighter? If everything is tight, and your alignment is good (not in spec but good) you don't even need a stabilizer in the first place...
There's many issues that can cause it. Bad tires, air pressure, bad shocks, an alignment issue or any worn component (ball joints, tie rods, track bar, radius arm bushings, wheel bearings, steering box......) mainly its caused by a worn component. Dry steering the system will wear out the front end quickly (you should only steer the wheels when the wheels are spinning, even very slowly is enough to help)
As far as an alignment, you'll want 4 to 5 degrees of caster (which is on the high end of the ford spec) and a slight toe in condition. Note that a leveling kit will lower caster.
As far as greaseable joint being stronger, I disagree. Take for example a ujoint. A Spicer ujoint that is non greasable is nearly double the strength of a ujoint that has a grease fitting.. it's stronger because it doesn't have a hole in it that reduces the area of the wear point..
Just my 2 cents. If you have death wobble, jack the front end up and look for something worn. It could also be the frame end of the track bar. Check that with the wheels on the ground and have someone dry steer the system bqck and forth. If you have excessive movement at the rubber bushing, it's bad.. generally the dealer will be useless because they will fix it for as cheaply as possible to just get you down the road and away long enough till it comes back...
Old Oct 1, 2021 | 08:47 AM
  #34
see77777's Avatar
see77777
We put a lift on out 2020 and it started to wobble. We are trying camber bushings at a different angle.
Old Dec 4, 2022 | 02:39 PM
  #35
Bluebummed's Avatar
Bluebummed
7th Gear
I spent way to much money at Ford dealerships on death wobble. I listened to all the “it has to be a worn part somewhere.”Finally a technician at a truck suspension shop, familiar with the problem, and having tried many fixes, solved the problem by installing a dual stabilizer. I had heard all the the “ that just masks the real problem.” Fast forward 50000 miles. I’ve had no problems since the install.
j MCQ
Apr 11, 2021 11:31 PM
Icthus in AK
6.7L Power Stroke Diesel
28
May 7, 2015 04:45 PM
bhaddox1
May 28, 2014 03:10 PM
Schaf279
Ohio Chapter
Sep 23, 2008 11:37 AM
tgene
Car/truck Buying Advice
23
Dec 28, 2007 09:17 AM
