No fuel
Old Jul 5, 2021 | 05:04 PM
Number4's Avatar
Number4
No fuel
79 F-250 460 stopped getting fuel.
I put a new fuel pump on, is it possible to fully install the pump, but have the arm not make proper contact?
I disconnected the fuel line at the tank and the pump and blew air through it, no blockage.
I blew compressed air into the fuel filler neck and fuel came out of the sender outlet.
There’s a new fuel filter at the carb.
I’m lost. Not familiar with older cars so much.
Old Jul 5, 2021 | 05:27 PM
Number4's Avatar
Number4
Well, ran hose to gas can and it fired up. Would a bad sending unit let gas out with compressed air but not via the fuel pump?
Old Jul 5, 2021 | 07:09 PM
1TonBasecamp's Avatar
1TonBasecamp
I can't say for sure with a 460, but I don't think that can happen with the Windsor family of engines. Too much of an interference fit and even on the low part of the lobe you must push inward on the pump to compress the arm and run the bolts up.
Might just need to be re-primed. I've had to do that many times when a new pump was installed. Sometimes you get lucky and the fuel just keeps siphoning up forward and the pump just keeps it going. Sometimes you gotta' make it work.
How much gas in the tank? More than half?
No. Can't imagine that happening. You may just need to prime the pump.
Or your new pump could be defective. Problem with new parts is that they don't always work anymore. So you can hope, but you can't count on them.
Paul
Old Jul 5, 2021 | 07:18 PM
AKsilvereagle's Avatar
AKsilvereagle
Last response on final posted quote I can relate to that....
Had installed a new fuel pump upon my fresh 390 rebuild waiting to start it up and break it in, only to find out this brand new fuel pump would not work and pump fuel at all....
Installed another new fuel pump I had onhand and it immediately started right up and ran....still working to this day with now reaching the 75,000 rebuilt mile mark on June 30, 2021.
There is other times like 1TonBasecamp stated with some fuel pumps - Sometimes you gotta' make it work.
Old Jul 5, 2021 | 07:20 PM
Number4's Avatar
Number4
Thanks for the info Paul. To prime the pump, just fill the hose from pump to tank? Can I fill from Carb connection down?
Historically, if the truck sat for a day, I’d have to put gas in the carb to get it to suck gas from the tank. Previous people had mentioned the carb needing work.
But how do you suggest priming the pump?
Old Jul 5, 2021 | 07:22 PM
440 sixpack's Avatar
440 sixpack
if it's the correct pump it has to make contact.
How long did you crank it ? it can take a while that's why I feed it a little gas .
You could have a hose leaking , not bad enough you'd notice it blowing air back but enough it breaks suction.
i have had the sock on the intake plug with junk and kill the engine, so you blow it back with air and it runs until it sucks the gunk back again. in your case since it doesn't run at all I'd be more suspect of the lines.
Old Jul 25, 2021 | 08:01 AM
Number4's Avatar
Number4
@440 sixpack cranked for some time. Usually putting fuel into the carb would help or suck gas.
moved to a fuel can off the fuel pump and it started fairly quick.
someone told me there’s something behind the float bowl cover that closes off when the trucks off. I know nothing of carbs. But basically, if this doesn’t seal it’s a vacuum break that would then cause the fuel supply line to drain back to the tank.
wondering if I couldn’t remove the cover and replace this part/seal while on the vehicle.
Old Jul 25, 2021 | 11:36 AM
5851a's Avatar
5851a
There is a joint in your fuel line between cab and box from factory. There is a section of hose there. It may be dried and cracked open. Just a thought. Gas lines can get rusted also and develop pin holes.
Old Jul 25, 2021 | 12:13 PM
redroad's Avatar
redroad
Our trucks came with rubber fuel line that will degrade with the use of fuel containing alcohol (rthanol). Replacing it all should be on your things of things to do.
You don't want to use old hose material compounded (manufactured) before the days of the alcohol blends, the gasolines we have today. Unless you know the exact rubber compound used on these old hoses as being alcohol compatible, they will degrade much "faster" with the modern gasolines, faster being a relative term here. Use modern fuel line materials compatible with alcohol by reviewing the specs from the manufacturer before you install it.
gprust
May 8, 2017 03:10 AM
Jbert50021
Nov 1, 2015 10:23 PM
Mr. Badger
Jan 12, 2011 06:44 PM
Shultzie
May 2, 2010 02:57 PM
wcsd106
Feb 7, 2008 10:56 PM
