77 ford 460 engine fuel pump question
Old Nov 1, 2015 | 11:55 AM
Jbert50021's Avatar
Jbert50021
Hi everyone,
Bare with me here - I usually work on newer vehicles so I may not make any sense.
I am looking at purchasing a 77 ford with a 460 engine.
The owner tells me it is not getting fuel, but that when he puts fuel directly into the carb that it starts up. He goes on to tell me it just needs a fuel pump.
I have never worked with a mechanical fuel pump so I did some research. In this case the fuel pump is mounted in the top front of the engine. It looks like an easy fix. It seems like a sure bet.
My question is this. What else could be wrong that could cause no fuel?
I figure that the cam could be broken, but that doesn't really make sense. Or maybe that the fuel lines or tank could be leaky or broken somewhere before the pump?
Any ideas?
Thanks
Old Nov 1, 2015 | 12:07 PM
Roger Carter's Avatar
Roger Carter
Hello, and welcome to the site.
If the rig starts when it has fuel the problem is most likely not cam or timing gear associated.
There are several different ways to prove out a truck's fuel system (lines, hoses, etc.) and they vary somewhat depending on whether there is one or more fuel tanks and whether , with multiple tanks, they are factory or aftermarket.
The easiest way (I think) to check a fuel pump is to disconnect the inlet line from the pump, install a section of hose to the inlet and drop the other end of this hose in a can of gas that is setting on the floor. Disconnect the fuel line from the carburetor and point it into a "catch can". Now crank the engine and see how much, if any, gas gets pumped out.
A fuel pressure check is always a good test too.
Good luck.
Old Nov 1, 2015 | 05:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Other problems, clogged in tank fuel sending unit pick up tube filter sock. Clogged in line frame mounted fuel filter, carb area fuel filter. Carb accelerator pump could be bad. If the fuel lines are broke they will mostly suck air, but will leak some fuel.
Yes the mechanical fuel pump is mounted to the dvrs side, fwd part of the engine. 2 bolts, 2 fuel lines and it comes right off.
If you have a a/c compressor bracket, it is under it and can be a PITA, but still doable. X2 on do some basic troubleshooting before dropping the fuel pump.
If it is the pump, make sure when you replace it you get the fuel pump ARM under the eccentric cam. We can walk you thru that part to, it is easy.
Old Nov 1, 2015 | 09:29 PM
84espy's Avatar
84espy
In my case, the fuel pump was just worn. It would supply fuel at idle and even when normally accelerating. When I would get on it, the engine would bog down. After changing a bunch of other stuff, I finally changed the fuel pump and now, it runs great. Sheer genius! If you do replace the fuel pump, you will be greatly assisted by changing your oil, since the job is much easier with the oil filter off.
Old Nov 1, 2015 | 10:23 PM
Ozzie H.'s Avatar
Ozzie H.
Exclamation
Originally Posted by Jbert50021
Hi everyone,
Any ideas?
Thanks
Many things can cause a fuel supply shortfall. Before replacing the fuel pump perform a pressure and capacity test. It is described on pages 24-30-1 through 24-30-3 of the 1977 Ford truck shop manual (vol.2). The required static pressure should be 5.0 - 7.0 PSI on the F series and a minimum flow volume of 1 pint in 20 seconds at idle speed. My '76 with the same engine once had choke and accelerator pump problems which affected starting. Clogged filters/strainers or cracked rubber hoses could also cause congestion or allow the entrance of air to the supply line.
gprust
May 8, 2017 03:10 AM
barrys00
25
Jul 29, 2007 03:22 PM
RedSkin12B
Flathead V8 & Flathead 6
May 22, 2007 05:48 AM
fordguy76
Dec 6, 2004 05:34 PM
shawn
Jan 15, 2004 12:34 AM
