Sound from dashboard area
Old Jul 4, 2021 | 12:08 PM
mikekozak's Avatar
mikekozak
I've included a video below. This is not the best video but I've had difficulty capturing this noise. Unfortunately it might be easier to hear the noise with headphones on. The noise becomes more prominent around 16-17 seconds in. Though its in and out throughout the video. While I rev in the video and the noise does follow it there slightly, it happens fairly independent of revving.
It's a higher pitch....not quite whine? Not a squeal? It doesn't sound at all like a belt. It sounds like nothing I'm familiar with.
Let me know if you can make it out and if you have any ideas what it is coming from. It's reasonably annoying and one of those things that gets you thinking a component wants to explode on you.
Old Jul 4, 2021 | 02:21 PM
sandymane's Avatar
sandymane
My hearing is not the best but that sounds like a failing fan clutch. Are you overheating as you use the truck? Does your fan blade turn easy by hand (engine off please). Does your fan blade seem to have slack or wobble if you wiggle it? These are some of the signs if the fan clutch is bad or heading that way. If so you want to replace it yourself ASAP and it is not hard to do. Sandy
Old Jul 4, 2021 | 03:10 PM
mikekozak's Avatar
mikekozak
Fan clutch was replaced, this sound predated the swap. Cooling is fine. No overheating climbing the hills on hot days. This sound happens on a cold engine as well, as soon as you start it up it starts intermittently sounding.
Additionally, if I have the hood open with the truck running, I don't hear it up front over the sound of the engine, only in the cab, which would indicate to me its something closer to the cab.
Old Jul 12, 2021 | 12:35 PM
mikekozak's Avatar
mikekozak
bumping for thoughts
Old Jul 12, 2021 | 01:01 PM
sandymane's Avatar
sandymane
It could be the air pump (or anything else) Get under it with a long screwdriver or piece of pipe and put it on the pump and see if that is where it is coming from when it does it. I know you can't hear it while it is running but the pipe can. If no luck move on around the engine. Can't emphasize enough to be careful of the fan blades. Sandy
Old Jul 12, 2021 | 01:51 PM
groundrat's Avatar
groundrat
Almost sounds like one of the HVAC actuators is really unhappy.
Old Jul 12, 2021 | 05:53 PM
wwhite's Avatar
wwhite
Or, could be A/C clutch coming on or off.
Maybe a pin hole in the air injection tubes, that's located between engine and firewall.
Old Jul 12, 2021 | 08:54 PM
TexasGuy001's Avatar
TexasGuy001
Is the sound coming from under the dash or under the hood? Try revving the engine the same way while checking the engine bay.
Old Jul 13, 2021 | 08:20 PM
mikekozak's Avatar
mikekozak
It sounds like its under the hood to me.
Old Jul 13, 2021 | 08:21 PM
mikekozak's Avatar
mikekozak
Happens without any HVAC running, if that matters.
fordman19762003
6.2L V8
Nov 18, 2021 10:36 AM
Jeremy Mathews
20
Feb 20, 2021 11:51 AM
jayman2
6.7L Power Stroke Diesel
24
Mar 17, 2012 07:00 PM
FordF350Baby
Exhaust Systems
32
Aug 27, 2007 09:52 AM
tabassak
Escape & Escape Hybrid
Nov 26, 2002 07:53 PM
