Radius Arm bolts
Old Jul 1, 2021 | 04:28 PM
Broomfieldbum's Avatar
Broomfieldbum
Radius Arm bolts
I am hoping someone here has some of the bolts i need to put my truck together. I need 2 384208-S2 bolts to attach my new 1975 Radius Arms to the I-beams. I cannot find them anywhere. I cut the old ones to get them off before i took the Suspension for Powdercoating.
If anyone has a couple, let me know.
Old Jul 2, 2021 | 12:03 AM
SuperSabre's Avatar
SuperSabre
This may be of no use at all, but I have a copy of the AMK Guide to Ford Fasteners, and I looked up your part number, 384208-S2, to see how it was described, which can be found on page 101, middle column, bottom square: Hex Head Special Bolt, 3/4 inch diameter - 10 threads/inch, 7.0 inches long, 4 1/4 inches of thread length, Grade 8 hardness, and S2 = Phosphate & Oil finish. Sounds pretty beefy. Hope you can find a supplier. Good luck.
Old Jul 2, 2021 | 07:01 PM
BobbyFord's Avatar
BobbyFord
Fastenal should have what you need.
Old Jul 3, 2021 | 12:26 AM
Broomfieldbum
Fastenal has bolts long enough, but Ford in their divine wisdom threaded them further than most people. I found them at wholesalebolts.com. I bought 6" bolts which will barely make length, but they are grade 6 and I can get the job done.
POPAJON
Feb 14, 2018 04:07 PM
gjgarre
Oct 6, 2012 02:11 AM
traxx808
Feb 9, 2012 03:30 PM
tracert1692
Feb 26, 2008 06:16 AM
WRECKTEC
Mar 6, 2005 06:09 AM
