I am looking to swapping to a Holley Sniper. If anyone has done this, I have questions.
I have a sniper on my 390, and it took a lot of tweaking but now it’s quite excellent. I have heard that both Holley and Edelbrock have great hardware but questionable support staff (they don’t seem to know their product), and FiTech has great folks but a less robust product.
The instructions suck. The forums are about the only place to get real info, mostly from one guy who honestly isn’t great at communicating but has a lot of answers. There are a number of things you’ll probably need to adjust that simply isn’t well documented if at all, and you’re just following forum posts (or hiring someone at a local performance shop).
One thing people should know is that holley’s temp sending units suck and are often way off, the forums mention a much better $10 directions replacement. Well worth it since decent temp measurement is critical even for learning mode. Just speaking from experience here…
I'm in the process swapping my 77 F-150, 351M/400 over to Holley 2300 EFI. The EFI is installed and I'm able to start the truck, but I'm working through a timing issue (4th attempt next), so I'm in no position to offer any advice / suggestions at this juncture.
IRT Holley's coolant temperature sensor, I mounted in it the block, passenger side front of the block, right behind the alternator bracket and the OEM temperature sensor in the goose neck. Next chance trying to get it timed should be this Saturday. Going to have to pull the Distributor to get everything lined up with number one cylinder at TDC. Done several projects before the Holley 2300 EFI swap starting just after last Thanksgiving 2020, almost eight months of back to back projects including changing the timing gear and chain. Plan to do a write-up on the EFI swap once it's running correctly.
Well I had an Holley EFI on my 74 f250 w/390 and ended up taking it off and went back to a carburetor. It was on the truck when I bought it and I couldn't get it to run right. Left me stranded to many times. Was always afraid to drive it. I tried to do adjustments to it and it would run ok one day and the next it would act up. I couldn't find anyone around me 6hat could help me tune it.
I saw a video not long ago, where Holley folks finally acknowledged that dual plane intake manifolds are problematic with TBI systems. I helped three guys install Snipers. Two were on Edelbrock Performer dual plane intake manifolds, one was on a single plane manifold. The single plane truck did fine. The two dual plane vehicles didn't run well. On one of those, I took the intake manifold off and milled the divider down 1.25" and we added an open 1" spacer. This effectively turned it into a single plane intake manifold. It now runs fine. You could probably use an unaltered Edelbrock Performer RPM Air Gap, since the divider is already gapped. The other guy went back to a carburetor.
That's a trick little spacer. Nice for getting the sensor below the thermostat so you can get readings before the thermostat opens. And it demonstrates the only known advantage in having the distributor at the rear of the engine. However, there's usually at least one port in the intake manifold that you can use. That pic shows two.
Ya, it looks like a better solution than the in-line hose type.
I wonder if a guy could add another sensor that goes to a water temp gage to verify what temp reading the Sniper is getting. Some, maybe a lot, of people put their Sniper CTS in the original water temp location at the back of the manifold, and their old gage sensor in the thermostat block up front.
IDK, which is the better location for accuracy and function, in your opinion, aside from convenience?
I don't know which is better, but I like having temp sensors as high as I can get them, since that theoretically should be the hottest location. I'd probably put it in the intake manifold crossover.
