Check engine light after full throttle
Old Jun 22, 2021 | 09:30 AM
Bob Sagget's Avatar
Bob Sagget
So something weird has been happening and I'm curious if anyone else has had the same issue. I haven't thrown parts at it but I'm pretty sure I have a failing o2 sensor (yay me right?). But something I've noticed over the past month is after about 2-3 full throttle pulls the truck throws a CEL for the rear o2 sensor, but ONLY after 2-3 sustained full throttle pulls (I'm assuming that's the cycle the computer needs in order to throw a code). If I drive like I normally do it shuts off after about 2-3 days and I don't have any other issues with the truck. No other symptoms such as fumes, smoke, misfires or odd idles. 5.4 3V with 196,000 miles.
Old Jun 22, 2021 | 10:23 AM
gDMJoe's Avatar
gDMJoe
Exclamation
Bob Sagget...
Vehicle information...
Given that you opt not to provide it in the post, put your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, maintenance, modifications, etc., etc.) in your signature. *Eliminates playing 20 questions when/if a post is made pertaining to your vehicle.
» Edit Signature « *Don't forget to [ save ] it.
Old Jun 22, 2021 | 01:41 PM
Bob Sagget's Avatar
Bob Sagget
For some reason I thought it was filled out. But not to be smart but I would figure 5.4 3v and 196,000 in the 09-14 F-150 section would be a dead give away.
Either way...maintenance includes, within the last 50-60K miles; new plugs, coils, timing assembly, oil every 4500-5000 with full syn high mileage and quart of Lucas, transmission fluid change with filter, differential fluid change.
2010 Ford F-150 FX4 5.4 3V 196,000 miles.
No other symptoms and scan tool doesn't find any oddities when running live data such as running super rich or lean at WOT and problem resolves itself within a couple days or within at least 100 miles.
Aftermarket bits includes a Magnaflow exhaust, 2 inch spacer level.
ThaBiggT
Sep 21, 2019 04:28 PM
ganzey
Jan 7, 2011 06:38 PM
magnet1
2004 - 2008 F150
Dec 17, 2010 02:29 AM
MF11283
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 28, 2005 06:57 PM
familyman
Dec 12, 2000 02:23 PM
