VIN Decoder and capacity Explanations
Old Apr 22, 2021 | 04:28 PM
Drsous1234's Avatar
Drsous1234
Hello Everyone. Im in the Market for a used 2009 F-150. I saw a good deal on a 4.6 V8 and am not exactly sure how to tell how much it can tow. Pardon my ignorance on this stuff. :-)
I used the VIN decoder on this site, but it has a lot of different weight capacities shown. Can anyone please explain what each one means? IE: Wt Distributing Hitch - Max Trailer Wt. 5200, 5700, 7500, 8100, 9500, 9800, 11300 lbs 5100.0 min 11300.0 max. What are the numbers separated by commas? Different models?
How do you know if you have a weight distribution hitch or not? I know the axle ratio varies on models too, but not sure how to know what that is either.
https://www.ford-trucks.com/forums/v...RW12819FB46304
Thanks for any help you can give me. Drsous
Old Apr 23, 2021 | 08:45 PM
Lime1GT's Avatar
Lime1GT
https://www.fleet.ford.com/content/d...VTTowGuide.pdf
Old Apr 24, 2021 | 08:57 AM
steve(ill)'s Avatar
steve(ill)
AS LIME posted... all those numbers do not pertain to ONE truck.. Each truck has a specific wheel base, transmission, engine, and axle ratio.. You look that up on the CHART and it will tell you the specs for YOUR TRUCK..... A 5.4 V8 with a 3.73 axle ratio is much higher load capable than a 6 cylinder with a 3.55 axle.
Old Apr 27, 2021 | 09:25 AM
Drsous1234's Avatar
Drsous1234
Well, im trying to buy a truck and nobody ever knows all the info on it. I thought the VIN# was supposed to have specific information like axle ratio so I could determine these things?
I just dont want to buy an underpowered truck of course. I guess there is no easy way to do this it looks like.
Thanks for the help. Jason..
Old Apr 27, 2021 | 09:32 AM
RLXXI's Avatar
RLXXI
The vin # does have specific information, this and many other websites vin decoders are useless garbage as they aren't actually decoding anything as you've no doubt discovered. Post the vin# here and I or someone else will be able to provide absolute data on a specific vehicle.
Old Apr 27, 2021 | 05:22 PM
Johnny Paycheck's Avatar
Johnny Paycheck
VIN decoders are generally garbage.
I think quite a few of them optioned my ‘03 XL into Lariats way back when. I wish!
Old Jun 20, 2021 | 08:44 PM
ohenry's Avatar
ohenry
I would recommend that you get a copy of the original window sticker. Those can be had, online, in PDF format, for about $8.
Old Jun 22, 2021 | 02:02 PM
Bob Sagget's Avatar
Bob Sagget
Look in your driver side door jam. You'll see the sticker with everything from your VIN to your axle code and paint code. Cross reference that with the Ford chart. If it has the 4.6, I don't believe that even in its highest form that it will tow above 7500-8000. But don't quote me on that. Also, make DOUBLE sure that your axle is the OEM one. If it's RWD, it's not uncommon for someone to grenade the rear end and swap in something different...Had that happen to me with an 01 Ranger and even my 2010 FX4 (they swapped in an LS diff instead of the electronic locking one. Long story short, I took it to the shop and forced them to install a new axle with the OEM E-locker in it). Once you've double confirmed this, you should be able to go to https://assets.forddirect.fordvehicl...1AA9446B1A.pdf
From there it's all pretty self explanatory.
Boxjockey
Feb 3, 2023 09:12 PM
thotfulremarks
All Things Towing
Mar 18, 2021 03:53 PM
tjanderson60
2015 + Expedition & Navigator
Oct 29, 2020 09:43 PM
G-Force junky
21
Oct 26, 2019 09:57 PM
AK Vet
May 1, 2018 09:39 PM
