Why level a truck?
Old Jun 17, 2021 | 08:43 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by last5oh_302
Mostly looks and to clear larger tires, but a level gives you a little more ground clearance. I did it on my last two F150s but I also didn’t tow anything heavy enough to sag the back end much. The F350 I have on order won’t see any of these mods. I don’t want to take away from towing performance.
On Super Duty trucks with solid front axles, unless you go with bigger tires you don't actually gain any ground clearance - the axle is still in the same relationship to the ground.
It DOES change your approach angles, however, which can help a bit.
Old Jun 17, 2021 | 09:20 AM
Split rims's Avatar
Split rims
Because you think it makes you cool.
It doesn’t.
Old Jun 17, 2021 | 09:41 AM
Norcalpr's Avatar
Norcalpr
Originally Posted by GM in a Ford
I see lots of posts about leveling kits and I am curious why people want to level a truck. Seems they ride a little higher in the back so they level out when you put a load on them. Is it just for looks or is there a practical reason for it? Maybe to fit larger tires?
because it's my truck and I can do whatever I want with it. 🤷‍♂️
Old Jun 17, 2021 | 10:01 AM
4wd6.7L's Avatar
4wd6.7L
It's done for different reasons, but in most cases looks. I personally don't like a true level stance, preferring some rake, but I don't like how little up travel there is up front. Take a look at how little space is between the front bump stops and pad. To gain some up travel I will probably bring the front up 1"-1.5", subjectively improving the look and increasing the up travel. Since my truck has 3"+ rake, I would still be left with some rake.
Old Jun 17, 2021 | 12:21 PM
C12H24's Avatar
C12H24
2WD trucks sit slightly lower and are leveled right off the assembly line. So, yeah, we 2WD owners are the OGs.
Old Jun 17, 2021 | 12:39 PM
acadianbob's Avatar
acadianbob
Originally Posted by GABAR
Just for looks and a larger set of rolling stock.
If there was a real problem with a truck having a rake, the OEM‘s wouldn’t engineer and sell them from the factory that way.
It's so they can complain about the rear end sagging in the rare event that a load is put on the truck. It also helps justify spending more money to bolster the rear suspension.
Old Jun 17, 2021 | 12:42 PM
ATLScott's Avatar
ATLScott
Because it looks better and fits 35-37" tires better.
In the end, it's your truck, do what you want to it. People will be jealous of your truck or they will hate it (most haters are just closeted on their jealousy), but what's it matter as long as you are happy?
Old Jun 17, 2021 | 12:50 PM
monckywrench's Avatar
monckywrench
Some vehicles are tools and some are toys. Either is fine as it's a free country and no one else's problem, but it would be wise if everyone changing the angle of their vehicle checked their headlight aim so they can see and so they don't blind others. (Approaching vehicle who can't see clearly may end up in your lap and not everyone has excellent night vision to compensate.
Some mods like the Carolina squat are functionally mongtarded and I suspect often due to buying too tall a vehicle for the owner, but at least if I buy one used I'll know it wasn't heavily loaded. I live in SC and enjoy it but it's not ~48th in education by accident and that reflects most everywhere including lowering vehicles in a state with many poor roads. I don't spend time staring at my trucks when parked preferring to use them instead but to each their own and it's still not as silly as sacking all four springs with a torch to get a ghetto low rider.
losttrail's Avatar
losttrail
I find the term 'haters' to be petty, small minded and highly overused. Just because someone disagrees, dislikes or differs in opinion, does not mean they 'hate' something. Labeling people as 'haters' due to a simple issue of someone having a different view is pretty small in my opinion.
Old Jun 17, 2021 | 01:48 PM
ATLScott's Avatar
ATLScott
Old Jun 17, 2021 | 02:25 PM
allendks45's Avatar
allendks45
It is not the opinion of someone who disagrees with my thoughts or actions but rather the delivery of that opinion. I've read several comments thus far in this thread that I'd throw a moniker of the highly overused term 'haters.'
Old Jun 17, 2021 | 03:00 PM
GABAR's Avatar
GABAR
Originally Posted by duckduke
So when u put a 100 lbs or more in the bed/hitch u can get a free Carolina squat!!
But if u level + shell out $$$ for an air bag system .... hey, u can keep it level all the time but u miss out on the squat. Oh well......
Lol…….The Carolina squat always remind me of a female dog taking a leak.
Old Jun 17, 2021 | 04:11 PM
  #28
2019er's Avatar
2019er
Because people have money to burn for no good reason? Then there's this...
Wait, are they only doing it in the Carolina's?
Old Jun 17, 2021 | 04:18 PM
  #29
B-ManFX4's Avatar
B-ManFX4
I like the look of my leveled truck. I like the improved approach angle when off-roading in my hilly / mountainous State. I also like not blinding oncoming traffic when I tow my dual axle trailer with tractor, bush hog, tiller, lime, fertilizer - so I added air bags in the rear. I personally think all the people who put wheels / tires that stick out way past the fenders are silly. Rocks chipping up the fender paint, rain / water being slung up the side of the truck, etc. Yet that seems to be a big trend nowadays. My truck was outfitted like that by the dealer. I promptly changed the wheels to move the tires back under the fenders as far as I could. I sold the dealer supplied Fuel wheels for enough that it covered the new wheels, mounting and balancing. No harm no foul.
To each his own. My only qualifier would be that the truck should be safe and legal to operate, in whatever configuration you choose to put it.
Old Jun 17, 2021 | 04:36 PM
  #30
Mainebucks's Avatar
Mainebucks
Level? Yes, and preferably jacked up 4-8 inches also, so you can put at least some 37"+ mud terrains on it. This gives you more ground clearance and it comes in handy on the old logging roads in Maine where you may have to traverse beaver dam floods, washed out bridges or deep snow. Not the best set up for towing, but I only do that on occasion.
