I see lots of posts about leveling kits and I am curious why people want to level a truck. Seems they ride a little higher in the back so they level out when you put a load on them. Is it just for looks or is there a practical reason for it? Maybe to fit larger tires?
While I am keeping my 19 stock, I find that a truck generally looks better if it’s level. The rake on mine is not too bad but for those that tow heavy or often with a level/lifted truck, they usually add air bags to keep the *** end from sagging. I would also say that the majority of lifted/leveled trucks you see driving around don’t tow anything significant with their truck. People spend a fortune for a “look” with no intent of really using their truck to its modified potential (been there done that). Maybe I’m just getting old but I’ve outgrown the need to go nuts with the mods. I knew I crossed over to the dark side when I added mud flaps and started receiving offers in the mail to buy a house in a senior community.
This 2019 F250 I currently have is the first truck I've ever had that has been leveled. Came this way and I like the look when it's not towing. However, when towing or hauling a significant load, the front end now rides high and at night oncoming traffic always thinks my high beams are on.
2022 F350 on order will likely get no leveling, I will move the RAS HD on the rear, from the F250 to the F350 however.
Looks and looks alone.
Lot's of posts on here about "levelers regret" because the truck now has steering issues and squats when towing.
A lot of really smart engineers gave these trucks "best in class towing" right off the showroom floor, and I'm just not going to mess with that, having ordered the truck purpose built for 5th wheel towing. I need the rake.
But I I'm a dull and boring old guy on a budget.
It's your truck. Do as you please. Being dull and boring may not be on your bucket list.
Mostly looks and to clear larger tires, but a level gives you a little more ground clearance. I did it on my last two F150s but I also didn’t tow anything heavy enough to sag the back end much. The F350 I have on order won’t see any of these mods. I don’t want to take away from towing performance.
I guess beauty is in the eye of the beholder.
I like the look of a little rake in a truck.
Leveling looks unattractive with a loaded trailer pushing the rear down,
For the record, I don't plan to level my truck. I bought it to tow an 8,000lb camper and need the rake so it levels out when towing. Just curious if there was a reason for it that I was missing.
Just order with the Snow plow prep or Heavy service front springs. It raises the front by about 1", but still leaves a little rake for towing and maintains factory steering geometry. .
but a level gives you a little more ground clearance. .
well its a one step forward,one step back kind of deal. it tilts the rear end angle down at the same time. to me this is why they look saggy. remember grampas old lead sled with front way up and rear dragging the curb
I go through thoughts of should I or shouldn't I level or lift. My 2020 is now 1-1/2 yrs old and the suspension is still stock. I knew I was getting old when I put the mud flaps on the front and back. Something I would of never considered a few years ago. .Mud flaps, dual steering stabilizers, Raptor steering wheel, new shocks, sway bar etc etc.. Im finding new ways to modify my truck and leaving the suspension stock.
Im getting older, maybe wiser? yes and probably not.
