Looking for your thoughts
Old Jun 15, 2021 | 05:32 PM
Tdavis8742's Avatar
Tdavis8742
I have a 2011 f150 xlt with 3.5 ecoboost it has 170k the Yet other day I was driving came to a stop light and the truck seemed to misfire when I pulled away from the traffic light the truck shimmered and shaped and I could not get more than 2 miles an hour I read the check engine light codes They are as follows
P0151. P0300, P0301, P0302, P0303, P0365 ,P0369
I'm not sure where to start
Thanks for any help you could provide
Old Jun 16, 2021 | 05:48 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Ok, welcome to FTE! The short of it is, your truck needs new plugs and possibly coils too.
P0151 02 Sensor Bank 2. May as well replace all four sensors. I'm surprised that your lasted as long as they did, mine were replaced starting at around 85,000 miles.
P0300 = Random misfires
P0301 Cyl 1 misfire
P0302 Cyl 2 misfire
P0303 Cyl 3 misfire
p0365 / 369 Lack of voltage from the camshaft position sensor Bank B
At 60,000 miles I replaced all plugs on my 2011 eco, at 67,000 miles the #2 coil went out. At 100,000 miles I replaced all plugs and coils as a preventative measure.
These ecoboost engines will tell on you if you're not keeping ahead of the maintenance.
So, you're going to have to spend a little time and money to get her perfect again. I'd start with the four o2 sensors and all the plugs and coils and see if that clears up the 365 and 369 fault codes. It may not and those codes may need to be addressed separately as you could very well have to deal with a timing issue such as cam phasers, chain, etc.
Old Jun 16, 2021 | 07:58 AM
BassFantasizer's Avatar
BassFantasizer
When I see multiple cylinder misfires I'm always suspicious of common parts, not simultaneous failures. (That said, I have seen simultaneous failures, too.)
Check the fuel filter and pressure before you buy parts. If you have access to any, you might want to run some diagnostics on the computer. Then again, a failing camshaft position sensor could cause all of the codes that you're seeing.
Tim knows a lot more about the ecoboost than I do and if suggests some serious maintenance at that mileage he's probably right. But in the short term, I'd look at just a couple of common parts....
Old Jun 16, 2021 | 12:13 PM
gDMJoe's Avatar
gDMJoe
Exclamation
BassFantasizer... Check the fuel filter and pressure before you buy parts....
*heads-up* As of 2009 there is no external, serviceable fuel filter. meaning: It's in the tank and associated with the fuel pump.
Tdavis8742...
In addition to other maintenance considerations... Clean the MAP sensors.
The EcoBoost has 3 MAP sensors ...
Old Jun 16, 2021 | 01:24 PM
Johnny Paycheck's Avatar
Johnny Paycheck
I’d solve that cam sensor circuit code(s).
For whatever reason, it’s not getting a signal to the computer and that makes fuel delivery a crapshoot, so you end up with misfires all along bank 1. This may solve the O2 sensor code once that is dealt with.
Start there. Don’t fire the random parts cannon as Tim suggests.
Old Jun 16, 2021 | 05:40 PM
RLXXI's Avatar
RLXXI
Check your engine wiring harness for critter damage, rats/squirrels etc love to chew on wires and can cause your concern and every one of those codes. I couldn't tell you how many engine harnesses I've had to repair/replace over the years for just such a scenario.
Old Jun 17, 2021 | 02:46 PM
steve(ill)'s Avatar
steve(ill)
Cam shaft position sensor voltage is bad ( cam / VCT/ wiring)... that causes the MISSFIRE... That causes the O2 reading out of whack... Dont do the O2.... Work on the cam shaft / sensor / VCT problem first.
Old Jun 22, 2021 | 02:54 PM
Tdavis8742's Avatar
Tdavis8742
It was a broken camshaft
Old Jun 23, 2021 | 05:40 AM
tseekins's Avatar
tseekins
Obviously I was way off base and thank you for closing the loop on this one.
I would also like to thank those who chimed in here with more appropriate responses than mine, good action guys. This seems to be really rare occasion, a camshaft breaking.
Old Jun 24, 2021 | 07:45 AM
BassFantasizer
Yikes! That kind of failure isn't as common as it once was. Do you know the vehicles maintenance history to know if it was serviced regularly?
RadioControlGuy85
Feb 11, 2017 07:41 AM
wrdabney
24
Aug 26, 2012 04:03 PM
broncos5332
Jul 8, 2011 01:21 PM
rustee90-150
Nov 11, 2007 05:03 PM
Captbo2001
32
Sep 22, 2005 05:06 PM
