check engine light stays on.
Old Feb 2, 2017 | 03:26 AM
RadioControlGuy85's Avatar
RadioControlGuy85
hey guys,
has anyone had this problem. check engine light came on couple days ago and will not turn. got parts on the way, but i cant get the light to reset.
left the battery unconnected over night and started it up. 20mins ago and the light is still on.
Old Feb 2, 2017 | 05:59 AM
'89F2urd's Avatar
'89F2urd
Did you pull codes?
Old Feb 2, 2017 | 09:08 AM
RadioControlGuy85
yes pull the codes,
just wanted to reset the light to see if it didnt read right cause the truck wasnt warmed up
Old Feb 2, 2017 | 10:01 AM
'89F2urd's Avatar
'89F2urd
Aaaand what were the codes, and what did you do to satisfy them?
Old Feb 2, 2017 | 12:27 PM
RadioControlGuy85
114 117 636
nothing yet, but shouldnt unhooking the battery reset it for a bit before it retrips the light
Old Feb 2, 2017 | 10:02 PM
Lead Head's Avatar
Lead Head
Depends on the fault. Some can show up instantly. Warm the truck up, disconnect the battery, reconnect, then get both the KOEO and KOER codes.
Old Feb 3, 2017 | 07:21 AM
rla2005's Avatar
rla2005
Originally Posted by RadioControlGuy85
114 117 636
I believe Codes 114 and 636 are KOEO only codes. Code 117 is listed as KOEO and CM. Codes 114 and 636 will not trigger a CEL, but Code 117, if it is in CM, will.
I assume you are leaving your code reader or paperclip in long enough to read the CM does? They are displayed after the KOEO tests are completed.
Old Feb 3, 2017 | 08:09 AM
RadioControlGuy85
yea i leave hooked up, untill its done,
just have to wait till the parts come in.
Old Feb 8, 2017 | 03:13 AM
RadioControlGuy85
ok got the stuff installed and light still on. left unhooked over night
Old Feb 8, 2017 | 10:07 AM
rla2005's Avatar
rla2005
A little more details please.
You left the battery unhooked over night and then what happened when you connected the battery cables?
Did the codes appear after starting and running the engine?
Are the codes from the KOEO tests or from Continuous Memory (CM)?
Old Feb 11, 2017 | 07:41 AM
RadioControlGuy85
i got it figured out, the senor was bad from the store got other one and she is fixed now,
thanks for yalls help
Goomer
Electrical Systems/Wiring
Feb 7, 2011 07:16 AM
rustee90-150
Nov 11, 2007 05:03 PM
Captbo2001
32
Sep 22, 2005 05:06 PM
lamarafronhe
Jul 7, 2004 09:10 PM
frdmike
Feb 28, 2004 01:09 PM
