Flywheel weight
Old Jun 15, 2021 | 09:56 AM
str8dogg's Avatar
str8dogg
Flywheel weight
Good afternoon "Ford Persons". It has been a minute, but i love coming here to gather info. I don't know if there is a thread already asking this, but i couldn't find it. My question is rather simple. I have a '89 with 302, 5-spd (Mazda tranny-M5R2). A few years ago, I cracked the block and found a replacement but am only just now getting around to messing with it to install. While removing any working parts from the old engine to compare and re-use on the replacement, I noticed the flywheel has a different weight. The cracked engine had the extremely heavy flywheel with the clutch kit. The replacement engine didn't have a clutch kit, and the flywheel was extremely light. I assume the engine was for an automatic tranny. I haven't done a thorough investigation yet until i start to clean the parts. My question is, are the flywheels interchangeable? Also, is there a balancing issue that goes with the flywheels?
Old Jun 15, 2021 | 10:45 AM
Conanski's Avatar
Conanski
You asked the same question here.... Flywheel weight and Interchangeability - Ford Truck Enthusiasts Forums (ford-trucks.com)
That thread is 3 pages down now so maybe you lost track of it. Did you see my answer there?
Old Jun 15, 2021 | 11:06 PM
sswari's Avatar
sswari
Quick answer is, no you can not use the auto flex plate with the manual transmission.
str8dogg
Jun 18, 2021 08:28 AM
Twinibeam1
Feb 13, 2019 12:56 AM
3TreeGuy
Jun 7, 2009 04:50 PM
RotGrubestier44
Jun 29, 2006 04:10 PM
RGAZ
20
Feb 3, 2001 08:36 AM
