Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air compressor/sandblaster
Old Jun 13, 2021 | 04:29 PM
F1 coyote's Avatar
F1 coyote
Does anyone know how to get better cfm pressure out of a air compressor rated at 16 cfm @ 90 psi, to get better pressure out for a sandblaster. I'm using a harbor freight 40 lb. model that just wants to push out sand with hardly enough pressure to push anything off. thx
Old Jun 13, 2021 | 05:49 PM
ford390gashog's Avatar
ford390gashog
That's a common issue with the pressure pot blasters. There is several good mods that should be done. Your blast media has to be dry and I mean dry. The biggest issue is the gun they include. There is better dead man style guns available. Also the 16cfm is only realistic if you are running 90psi at the pot. Make sure you are using the proper 1/2" fittings and hose or you will not get the rated cfm. To avoid pressure drop you will need higher outlet pressure and you should set it to 90psi with the gun depressed (don't exceed overall staic working pressure of the pot).
Old Jun 14, 2021 | 05:49 AM
F1 coyote's Avatar
F1 coyote
Thanks I appreciated the help, Ill give it a shot.
Old Jun 14, 2021 | 06:08 PM
daveengelson's Avatar
daveengelson
Had an urge to chime in. I have a similar set up and found learning to regulate the pressure to the amount of media is important in regulating the lower media supply valve to the pressure pot air flow valve in an effort to obtain the best balance. I also have a HF cabinet blaster so I use the existing hose opening and combine the pot blaster with the cabinet and Oh yea, works very well for me.
As for keeping the media dry, particularly during the winter months I use a 'Golden Rod Wand' and insert it into the pot blaster when not in use?
Use to purchase deadman guns from HF but found Northern Tools offers a much better gun.
Stumbled upon a commercial grade media and blaster supplier relatively close and a great source for various type of media cheap. I had problems with the larger grit media constantly clogging up the nozzle, I keep a skewer close to clear the nozzle. .
Finally, media can travel quite a distance and annoying to neighbors, and invade every orifice known to the human body, suggest protective gear and try confine project. I have a cheap 4X4 enclosed tent I am considering using?
Old Jul 8, 2021 | 05:50 PM
Jamey Eaton's Avatar
Jamey Eaton
Have you had better luck, & what size air compressor are you running??
NoFrod
Large Truck
Sep 26, 2016 06:52 PM
Phinxter
Garage & Workshop
Sep 26, 2009 02:34 AM
MBDiagMan
Paint & Bodywork
Nov 10, 2007 06:18 PM
73FOMO
Paint & Bodywork
Jun 23, 2007 12:30 PM
rwr
Paint & Bodywork
Sep 12, 2003 02:06 PM
