Leveling kit questions
Old Jun 11, 2021 | 06:19 PM
ChevyExterminator's Avatar
ChevyExterminator
Ever since I got my 77' F100, I have hated the difference in height between the front and rear wheels. The back is about 2 inches higher than the front, making for an awkward stance. I know this is from factory and there is nothing I should be concerned about mechanically wise, but its just weird. I'll have to look more into this, but I was wondering If I could just do a body lift at the front to level out the height difference.
My questions are...
A. Is it possible to level it out without getting new coils and springs?
B. What the actual height difference is? I measured earlier today and got 2.5" difference, but I have seen online that it is 1.5", 2", and 2.5". (I know .5" doesnt make much of a difference, but I want to get it the best that I can.)
C. Reference/tutorial videos or guides?
D. Any modifications or problems that I might encounter while doing it?
Thanks, Sam
1977 F100, 2WD, 302, 3spd manual on the column
Old Jun 12, 2021 | 06:14 PM
ChevyExterminator
After some thinking, body raising just the front would leave a gap of sorts where the cab meets the bed. I looked at coil spacers and was wondering if they would work. Anyone have experience with them?
Old Jun 12, 2021 | 06:18 PM
ford390gashog's Avatar
ford390gashog
My questions are...
Thanks, Sam
Either lower the rear or do a front leveling kit which will involve having the I beams bent.
Old Jun 16, 2021 | 09:44 PM
ChevyExterminator
Ive seen a few videos where they just slap the spacers on and nothing else. Anybody know anything about it?
Old Jun 16, 2021 | 10:48 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I believe those coil spacers can cause a caster/camber issue on 2wd. What about taking the OEM rear axle block out and using one 1/2 a tall?
Old Jun 17, 2021 | 06:32 AM
somethingclever's Avatar
somethingclever
I have a 3” rear lowering kit I am not using if you are interested.
Anything in the front will require alignment corrections.
Old Jun 22, 2021 | 04:37 PM
ChevyExterminator
I agree that lifting the front would cause too many problems, and lowering the back is now the solution. I guess the plan is to lower the back by probably 1.5". I looked and there were no axle blocks, so getting smaller ones would not work.
2. After leveling, could I then do a 2" body lift just for the hell of it, and still have it be level?
Old Jun 22, 2021 | 08:25 PM
Flecker's Avatar
Flecker
yes.......
Old Jun 23, 2021 | 08:36 AM
Evan76's Avatar
Evan76
Lowering the rear will increase front Castor and all around make the truck track starter down the road.
Old Jun 23, 2021 | 08:53 AM
ChevyExterminator
Im not super worried about the caster changing, as many people do it. Another thing I thought of though is to body lift the cab, and body lift the front part of the bed. It would still raise the front, but would not make a gap
Old Jun 23, 2021 | 08:59 AM
Doosenberry's Avatar
Doosenberry
Just put some sand bags in the bed and call it a day. You're tossing out some bad ideas. Body lift 3/4 of the truck? Really?
Old Jun 23, 2021 | 08:04 PM
ChevyExterminator
Anybody recommend a good 2” drop shackle for my truck?
Old Jun 24, 2021 | 09:57 AM
Evan76's Avatar
Evan76
I agree. Body lift some of the truck wtf
Old Jun 24, 2021 | 11:14 AM
symonds86's Avatar
symonds86
i pulled the over load/helper spring out of my stock packs and it dropped about an inch, or a set of shackles like this will drop the rear 2 inches drop shackles. I wouldn't body lift half the truck, the front bumper wont fit right and you body lines will never match up. Also a body lift is alot of work I have done both body and suspension lifts and I would rather do a suspension lift myself.
nddragon01
2015 - 2020 F150
Jun 14, 2020 01:37 PM
bigwillisF150
Jan 21, 2012 08:02 PM
14&Ford
Feb 1, 2011 11:34 AM
Cluney93
Dec 17, 2010 01:07 PM
robbie1
Apr 22, 2004 04:09 PM
