68' starter grinding
Old Jun 3, 2021 | 02:29 PM
Smalldevil's Avatar
Smalldevil
6th Gear
Have a 1968 f100 , been off the road since 81.
engines free , can turn it by hand but whenever I try to turn it with key the starter grinds, installed a new starter and still grinds and doesn't turn over.
Any advice ?
360 with 3 speed manual
Old Jun 3, 2021 | 06:09 PM
sklbaj's Avatar
sklbaj
Is it in neutral?
Old Jun 3, 2021 | 06:52 PM
john jamieson's Avatar
john jamieson
Check all of your electrical connections and wires. What shape is the battery in?
Old Jun 3, 2021 | 07:44 PM
fe390pc's Avatar
fe390pc
I would pull the starter and look at the flywheel. Make sure the teeth are in good condition. Also try the starter out of the truck and insure the bendix is moving out correctly. Like John said, verify your battery is fully charged and your connections are good.
Old Jun 3, 2021 | 08:31 PM
Smalldevil's Avatar
Smalldevil
6th Gear
So after looking under the truck , the starter doesn't engage at all , instead what I was hearing was the starter solenoid kicking around , almost grinding. I assume it's just time for a new solenoid?
obscurity
Jun 1, 2017 05:06 PM
Bigtruc
20
Oct 16, 2012 09:56 PM
chazman
Apr 23, 2011 05:21 AM
lola13
1983 - 2012 Ranger & B-Series
Aug 18, 2008 02:13 AM
emfitz79
Oct 2, 2007 05:53 PM
