Starter works sometimes
Old May 28, 2017 | 02:48 PM
obscurity's Avatar
obscurity
I seem to be having intermittent starter issues. Many months ago i replaced the original starter with a mini starter. And everything worked pretty well. Now half the time when i turn the key the starter doesn't do anything. No turn, no click, nothing. The fuel pump(electric) does turn every time. Once or twice i have turned the key and nothing but held it there for an extra second and out did turn other times continued nothing. Any ideas?
Old May 28, 2017 | 03:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It sounds like you are using a non-stock ignition switch with integral starter contact? Have you checked all the wiring?
Are you using the stock Ford solenoid to trigger the starter? If you activate the solenoid with a jumper, does it crank every time?
Old May 28, 2017 | 04:42 PM
obscurity's Avatar
obscurity
You are right it is an after market that i have not had issues with before recently so i am assuming it is wired correctly but i will look into a diagram and how to activate the solenoid.
Old May 28, 2017 | 05:23 PM
obscurity's Avatar
obscurity
I forgot to say thanks for the tip!
Old May 28, 2017 | 10:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As far as the wiring, I meant to check to see if something simply came loose. Not uncommon for wires on the ignition switch to come loose. Clearly you have it wired correctly.
Old May 29, 2017 | 02:06 PM
petemcl's Avatar
petemcl
I assume that you have changed from positive ground to negative ground? 6 or 12v? Since you are using the key you are no longer using the starter button? Did you change the solenoid or the wiring to the battery? Pictures?
Old May 29, 2017 | 07:32 PM
Nice ol' Dave's Avatar
Nice ol' Dave
I just had a similar problem with a "Stump Puller" starter I got from Summit Racing. Found out Summit doesn't build or warrant these and had to return it to Power Master in Chicago.
Their guy John Babcock was great to deal with and luckily mine was still within the warranty period.
John had several tips. Clean connections, check battery voltage, clean mounting surfaces, etc. The turn around time was only a couple days and now I am back in business.
Old Jun 1, 2017 | 09:05 AM
obscurity's Avatar
obscurity
yes it is a 12V negative ground with a key and no push button. The conversion was done before me and has a solenoid mounted on the firewall. Until recently I had the original starter but recently changed for a ministarter. In looking at the wiring I would not say it is original but I don't know if it differs from the original layout. It runs when started like you might expect. The starter is just intermittent.
Thanks,
John
Old Jun 1, 2017 | 09:08 AM
obscurity's Avatar
obscurity
I will check the connections around the switch but everything else is recently cleaned. I hope it is not the starter itself. did they say what was wrong with yours? Mine is a Powermaster. When it turns it starts strong
Old Jun 1, 2017 | 10:30 AM
petemcl's Avatar
petemcl
Since you didn't change these the most likely culprit are your battery cables and perhaps the cable running from the solenoid to the starter. They should be larger than the normal 4 gauge 12v cables if they are original 6v. Normally they would work just fine but they do corrode. Pay particular attention to area where the wire goes into the connectors. Remove the cable from the battery and clean inside where the battery posts fit. Also clean the posts. A solution of a tablespoon of baking soda to a cup of hot water will dissolve any corrosion. Just be careful not to splash it on anything (the resultant foam will eat right through clothing and burn skin). Let it sit for 5 minutes then rinse thoroughly with low pressure water (do not splash).
Old Jun 1, 2017 | 10:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The smaller wire on my mini-starter (which triggers the starter) has come loose once or twice, check that.
Old Jun 1, 2017 | 05:06 PM
ssj7kids's Avatar
ssj7kids
WOW, I haven't been on hear in a LONG time....
I have chased intermittent starter problems right up to two days ago... I was going to come tell you guys about it. I still have original starter and 6v Positive Ground.
Everyone will tell you to MAKE SURE your connections are good, clean and solid.. This is true-dat. I focused on my grounds, to my hurt... At one point it turned out that my positive terminal wire connection was compromised... Did you know lead melts at 621 degrees F? I do.
I moved in January... Mater started fine... drove to his new GARAGE. A week later I was bragging on him, and was going to start him..... NOTHING... CLICK. period. Every couple weeks I would attempt... CLICK... So I FINALLY had some time Sunday afternoon and I dropped the starter...
GO AHEAD, ASK ME... What was wrong?
MICE had pulled wadding into the bell housing and a small amount had wedged between the starter gear and the ring gear...
Cleaned it out and it started like a champ.... I was glad it cost me $0.00 to fix, but frustrated I fumed for 5 months that it once again wouldn't start.
Gotta love these old trucks.
Missed being here too. Good to see some familiar names.
Blessings,
Steve
wicat3
Oct 3, 2012 05:46 PM
johninraleigh
Aug 27, 2010 05:20 PM
lola13
1983 - 2012 Ranger & B-Series
Aug 18, 2008 02:13 AM
cdorroh
Feb 5, 2005 11:32 AM
Gates
Apr 19, 2003 05:55 PM
