starter intermittently will not kick in to turn over engine. the starter runs but wont engage. also sometimes it wont quit even if i pull out the key,....
What you need to do is reverse the magnetic polarity of the gravametric field generator to an inverse pulse rating of not less than 2.367 quantum mili-second bursts. Keep in mind, you must not create a reaction with a deflection of .432 in the phased harmonic inducer or the iso-spatial stream manifold can overheat.
On second thought, just replace the starter. It'd probably be easier.
Stewart
You forgot the flux capacitor and run a sub-space frequency diagnostic first, Picard.
So if I reroute the obsogill that creates the giglipen and eliminate the attempt of the blazate to over ride bumpuckaroo of the caca, you two think it should in turn compensate for overheating of the arandous.Good point guys, you Jagoffs
JH818 you hopped up on Sierra Nevada brew or the other cash crop out there?A good friend of mine is a big wig at SN..Might be rolling out to do the wine tour in Napa and visit him in the fall.
