4r100 with endless fluid
Old Jun 2, 2021 | 01:42 AM
Mikethezipper's Avatar
Mikethezipper
Short version: My tranny is leaking fluid and seems low - but dipstick always reads slightly past full no matter how many ways and times I check it.
Long: About 2 weeks after installing my John Woods valve body, my 4r100 started belching up a lil tranny fluid. I spilled maybe 1/2 a quart of what had been in there since the rebuild, but the dipstick said it was a lil past full so I left it as is. Well, it's still belching up some oil that looks like its coming from where the dipstick tube meets the lil 6" tube that comes out of the pan. It's been leaking every single day, and not a small amount. I wouldn't be surprised if it's lost 6 quarts by now.
Shifting has been getting worse and now it's throwing SES light and throwing codes for 1-2 and 2-3 shift errors and incorrect ratio for gear #2
I've tried every permutation of checking the tranny oil level- and no matter what it always reads slightly above the full at hot mark.... What gives?
Old Jun 2, 2021 | 06:40 AM
FordTruckNoob's Avatar
FordTruckNoob
My guess is something did not get put back in the right place during the valve body swap, probably the check *****, items 186 and 189 below.
Old Jun 2, 2021 | 08:13 AM
FinnishStroker's Avatar
FinnishStroker
That diagram makes me wanna do some tranny overhaulin..
Old Jun 2, 2021 | 08:35 AM
FordTruckNoob
LOL. Running out of projects?
Old Jun 2, 2021 | 10:13 AM
Mikethezipper
Before I did the valve body swap (which was just a swap, no other work was done), I had the tranny rebuilt in mexico a couple months before this.
During the valve body swap - I didn't do anything besides swapping the entire valve body - did I have access to a check valve that I could have screwed up? I thought the valves were on the other side of the plate I didn't remove (items 190-192). I saw a thread mentioning that there were feed screws and check valves in just the valve body itself (that I did swap) - I'm wondering if maybe the unit I got had something missing or loose.
Thanks for your help on this - I'm totally lost and at my wits end with this tranny.
Old Jun 2, 2021 | 04:27 PM
Capt'n Jack's Avatar
Capt'n Jack
That diagram scares the poop out of me! Auto trans is one thing I have never had the cojones to tackle. Maybe retirement will give me the time to learn it.....
Old Jun 11, 2021 | 12:38 PM
Mikethezipper
@FordTruckNoob Based on the research I've been doing - it looks like there are a ton of check b alls in the tranny, except I don't see any in the part of the valve body that I replaced. Considering the tranny was recently rebuilt - it's possible that any one of those check b alls was not reinstalled properly (or missing altogether)
Were there supposed to be any check b alls that I can access during a normal valve body swap? To me it looks like all of the check valve b alls are in the other half of the valve assembly that isn't touched, or behind the main separator plate.
The idea that a check ball not being installed makes sense in that fluid that should be up in the tranny is draining down and always showing a high fluid level - that's an great catch.
@Mark Kovalsky is there any way for me to get an idea of which check ball could be the culprit? If it's behind that main plate, I don't see how I can fix this without pulling the tranny.
Old Jun 11, 2021 | 01:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That diagram doesn't show the pump. As I recall the torque converter drainback valve is in the pump body, not the valve body. And yes, you have the remove the trans to get the pump body out.
Old Jun 11, 2021 | 01:59 PM
Mikethezipper
FordTruckNoob's theory was that it was a check ball in the lower half of the transmission, not the TC drainback valve. My transmission knowledge and nomenclature are off so not sure what to call it, but everything connected to the valve body and the 8+ check ball(s) in that was what I believe he was referring to.
Do my symptoms seem more like a torque converter drainback valve failure? I believe I've seen a diagnostic test to see if the TC drainback valve is failing. I can try doing that this weekend to see if I can narrow it down. Thank you all for your help!
Old Jun 11, 2021 | 03:58 PM
Mark Kovalsky
Here is how to tell if the drainback valve is leaking.
Drive the truck to get the trans up to at least 150°F. Park on a level surface. Check the fluid level with the engine idling and the trans in park. Shut the engine off and let it sit at least 8 hours. Check the fluid level BEFORE starting the engine. If it shows WAY overfilled, the torque converter has drained into the pan due to a leaking check valve.
I don't know of any check ball in the pan that could cause this.
Old Jun 12, 2021 | 05:30 AM
FordTruckNoob
Well, Mark Kovalsky is the resident transmission expert so I'd listen to him.
As for the rebuild in Mexico, watch the videos in this thread. It will give you an idea of how easy it is to screw things up when putting one of these transmissions back together.
Old Aug 4, 2021 | 02:15 PM
Mikethezipper
My tranmission dipstick tube was bent to hell and not properly seating into the transmission. I ended up bending it so it aligns properly and seats. I think that's related to my off-base fluid readings.
However it still drives like total crap. Takes many tries and a long time to shift into D or R, and shift flares all over the place and it's throwing codes like a ****.
I had the transmission rebuilt with all new parts a thousand miles ago, new billet TC, new valve body from J Woods, and way too much of my time.
At this point I want to just move forward with my life. Do you guys think I should take it to a shop and let them figure it out with my existing tranny, or just throw the whole thing away and put another one in there? It looks like the only tranny I could afford (dieselsite) is Out-of-stock indefinitely, so I'm looking at this one on ebay:
https://www.ebay.com/itm/28327137284...oAAOSwWnFV8dWq
What do you guys think? I don't tow anything, 160/0 injectors, and I don't plan on owning it for more than another year. What would you guys recommend?
Old Aug 4, 2021 | 10:55 PM
z31freakify's Avatar
z31freakify
I've had good luck in our fleet using the transmissions Autozone has access to. 3 year unlimited miles is nice, luckily I haven't had to use the warranty on many that I've installed including on my personal truck.
Also what are the codes could be something simple
Old Aug 5, 2021 | 03:14 AM
FinnishStroker
So you had another rebuild after mexican build?
Have you tried different tunes etc.?
Go with another tranny since you have the welded bellhousing and current one just dont let itself to be rebuilded..?
Old Aug 5, 2021 | 12:22 PM
Mikethezipper
No it hasn't been rebuilt again - I just haven't really driven it much since the rebuild.
I haven't tried getting new tunes - but my tranny is also throwing a bunch of codes so I suspect that there's more going on than just a tuning issue for shifts. I'll try installing my hydra unit and see what effect that has.
With how the bellhousing is cracked (it's been rewelded very well), I don't think it impacts it's performance. The issues I have seem more likely to be an issue with the rebuild.
If I get a "new" tranny, I also have to pay for a core since nobody will accept mine as it is.
So any rebuilt unit will cost $1000 core charge + $3000 min for the tranny. The cost for pulling and reinstalling the tranny will be the same for fixing vs installing a rebuilt unit.
If I could get it fixed locally for less than $4k that would be great... but I don't know if I can trust anyone locally to know how to actually fix this issue - and I don't want to end up exactly where I already am. I'll check out autozone's offerings and see what's up
ah1988
Mar 18, 2011 11:43 PM
krankshaft
Aerostar
Oct 16, 2008 07:44 PM
whitesdford
Oct 9, 2007 09:35 PM
dassmoof
1978 - 1996 Big Bronco
Jun 28, 2004 09:33 AM
cjben
Mar 6, 2003 09:24 PM
