Tranny dipstick
Old Mar 18, 2011 | 08:48 PM
ah1988's Avatar
ah1988
Tranny dipstick
I just replaced my tranny fluid and put on one of those extra deep tranny oil pans and i cant really tell the level of the fluid because when i insert the dip stick wipe it off insert it again and look at the dip stick on the side with the crosshairs are there is only a little fluid on the tip, but on the back side of the dip stick from the tip up about 2inches is coverd in atf ! What is up with that i turned the truck on and ran it throgh the gears and i got the same result , any help or tip's has anyone else have this happen to them ?
Old Mar 18, 2011 | 09:17 PM
84-6.9L's Avatar
84-6.9L
Its caused but the atf sitting in the tube. If you check it in a few hours or in the morning you will get a better reading
Old Mar 18, 2011 | 09:34 PM
ah1988's Avatar
ah1988
Ok, thanks thats what i was going to do, i just wanted to make sure it wasnt a sighn of something broken or gonna break really cant afford to mess something up .
Old Mar 18, 2011 | 09:36 PM
84-6.9L's Avatar
84-6.9L
Nope your fine it just does that because of the angle of the tube
Old Mar 18, 2011 | 11:43 PM
wreckinball's Avatar
wreckinball
test has to be warm, with trans in park. It will be a false reading otherwise.
Stonesetter1
Jan 14, 2015 09:06 PM
Brnfree
Nov 17, 2014 11:25 PM
vogey
Nov 9, 2004 05:05 PM
xman7896
Sep 1, 2003 09:12 PM
