Aerostar Ford Aerostar
Reading Tranny Dipstick
Old Oct 16, 2008 | 04:01 PM
krankshaft's Avatar
krankshaft
Well I just got done with the flush and fliter change and the fluid is nice and red.
So the van is parked on my garage floor and I fill it up and put the dipstick in. I happened to notice when the pan was off that the stick enters at an angle.
One side of the dipstick has more fluid on it than the other.
Which side do I read? Is this because my garage floor isn't as level as I think it is?
In addition to that the Ford service manual says that the tranny fluid level is fine when the engine is heated up in park and running when the fluid is in the crosshatched area.
Then what are the two holes for? Is the tranny fluid supposed to be between them when the engine is cold?
Old Oct 16, 2008 | 07:44 PM
Aeroman59's Avatar
Aeroman59
I think the bottom hole is a "do not drive" warning level & the top is 75*F level with engine off. The actual oil level when warmed up idling seems to be quite fussy on these tranmissions & the angle of the dipstick is probably the reason for it. I think oil splashes up the dipstick tube & gives a higher reading than actual so you need to look for the lowest level where the oil saturates the dipstick all around.
