Sponsored by: Real Truck
transmission fluid FLUSH OR Drain/Fill??
Old May 25, 2021 | 04:58 PM
Dieselcyrus's Avatar
Dieselcyrus
I have a 2008 F250, 6.4l diesel with 140000 miles. Would you power flush or just an old fashion drain/fill transmission fluid???
Old May 25, 2021 | 06:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A powerflush is impossible. I recommend this procedure: https://www.ford-trucks.com/forums/1...-exchange.html
Since there is no drain plug in the torque converter you can only drain the pan, which will only remove about half of the fluid.
Old May 25, 2021 | 06:43 PM
leadmic's Avatar
leadmic
Drop the pan and change the filter replace the oil. If you are worried about not getting all the old oil out drop the drain plug and change the oil in the pan every other oil change.
engine
Old May 25, 2021 | 09:49 PM
Rudiak's Avatar
Rudiak
I have a 2008 f250 6.4. I let the Ford dealer do the hot flush every 90k. They said the filter is lifetime. I'm at 220k right now and never had any transmission issues.
Old May 25, 2021 | 10:53 PM
leadmic's Avatar
leadmic
The pan filter definitely not lifetime.
Old May 26, 2021 | 06:42 AM
Mark Kovalsky
There was a running change in 2008 that changed the pan filter from lifetime to needing a change. If yours was built in the first half of the model year it was lifetime. If it was built in the second half you are way overdue for a new filter.
Old May 26, 2021 | 09:56 AM
speakerfritz's Avatar
speakerfritz
I did a spreadsheet once....it takes 17 drain and fills to get 100% of the old fluid out.
Old May 26, 2021 | 01:13 PM
Motohead911's Avatar
Motohead911
The method Mark K references works really well, and is pretty easy to do.
bmuhlbach
Escape & Escape Hybrid
Apr 26, 2015 08:12 PM
Subzero68
Oct 18, 2014 09:56 AM
speakerfritz
Jul 30, 2014 03:18 PM
F0rdE$cape
Apr 21, 2014 05:01 AM
bengerman
May 15, 2012 11:16 PM
