Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2010 trans fluid change.
Old Apr 25, 2015 | 08:27 PM
bmuhlbach's Avatar
bmuhlbach
Has any one done the trans fluid change on the 2009 -2012? Is it the same as myCD4E drain 4 refill? I know its a different fluid probably buy from Ford.
Old Apr 26, 2015 | 08:12 PM
speaser's Avatar
speaser
I drain and refill three times. drain then refill with 4 qts. drain then refill with 4 qts. drain and then refill to correct level per dipstick. believe this takes mercon lv. my 12 does anyway. between each refill run through the gears each for approx. 5 sec. and before let warm up to operating temp.
bengerman
May 15, 2012 11:16 PM
B 3000
Feb 18, 2010 06:41 PM
mictro
Jan 24, 2009 04:31 PM
tobyw
Jul 10, 2007 05:52 PM
Borgunit
17
Sep 7, 2004 09:02 AM
