P144c
Old May 24, 2021 | 08:50 PM
Jaybyrd's Avatar
Jaybyrd
P144c
Hello this is my first post here and i would like to get to know more about my truck. I have a 2016 ford f 150 with 3.5 EcoBoost. Had an engine light appear on my dash and the code pop up as p144c. So the evap canister was bad order another one, install it ran great for a week. Today the engine light appear again and its p144c code again I'm stump this is a brand new one from motorcraft i just install, any
info will be appreciated!!!
Old May 24, 2021 | 11:15 PM
McObra's Avatar
McObra
Check for leaking, split, disconnected hoses in the evap system, going all the way back to the tank. Easiest way is to have someone smoke test the evap system.
Old Jun 1, 2021 | 11:44 AM
TJReams's Avatar
TJReams
One other thing Is do NOT "top off" the fuel tank. I see people stuffing every drop of gas in the take till it actually comes up to the filler. If you have every done that you need to check for bad check valves, other wise it will keep knocking out evap canisters. I have worked in a fleet garage and saw it happen many many times. We actually assigned a fueller and he paid his own salary with the saving from repairing the fuel evap systems.
TJ
Old Jun 1, 2021 | 11:48 AM
ingman's Avatar
ingman
TJ, thanks for the heads up. I don't do that, but I round up to the next dollar. Maybe I'll stop that too.
Old Jun 1, 2021 | 12:39 PM
Jaybyrd's Avatar
Jaybyrd
TJ
yeah i never do that, good thing to remind people of that 👍
Old Jun 9, 2021 | 09:01 PM
Jaybyrd's Avatar
Jaybyrd
Finally found the culprit that was given me p144c code, hope this helps anybody with a similar problem.
Old Jun 10, 2021 | 04:36 PM
GABAR's Avatar
GABAR
How’d the repair go and did the code go away afterwards?
Old Jun 10, 2021 | 04:41 PM
Jaybyrd's Avatar
Jaybyrd
P144c
The repair was straight forward no issues whatsoever, clear code and disconnected the battery. No more rough idle truck drives great again.
Lucas Frink
1978 - 1996 Big Bronco
Jul 1, 2019 09:04 PM
Steelhant
Jun 19, 2017 04:44 PM
slowmans
6.4L Power Stroke Diesel
May 24, 2011 06:21 PM
JoggingGuy
1983 - 2012 Ranger & B-Series
Dec 10, 2003 05:02 PM
Raja2973
Jun 10, 2003 11:51 AM
