460 swap
Old May 23, 2021 | 11:53 AM
bobs 80 f250's Avatar
bobs 80 f250
460 swap
Can I swap in a 460 motor into a truck that has a 351m motor without changing the perches??
Old May 23, 2021 | 06:18 PM
Franklin2's Avatar
Franklin2
Theoretically yes. I can't remember if anyone on here has done it recently. Should bolt up to the trans also. Going by memory, I think the automatic will bolt up no problem, but the flywheel for the 460 on a manual setup might be too large for the clutch bell for the 400/351m. Someone else might remember, but think there is a interference problem with one of the bellhousings.
The trucks equipped with 460's also had a special front crossmember that had a dent in it for oil filter clearance, and it had a specific oil filter adapter bolted to the engine. If you do not have the dent, you will have to buy a aftermarket remote oil filter setup to make it all work.
Matts56F100
Offroad & 4x4
Jan 21, 2021 06:44 AM
bigolfordtruck
May 23, 2006 04:38 PM
highboy1975
Mar 21, 2004 07:15 PM
98screamer
Aug 18, 2001 10:48 AM
