Tin in oil?
Old May 19, 2021 | 04:21 PM
doublenot7's Avatar
doublenot7
Tin in oil?
Prior oil change and upper oil pan seal change I had metallic non-magnetic shavings in the oil pan and drain pan. Almost 3K miles later I got an oil sample along with another oil change. No shavings in the drain pan. But tin content is high. Where is the tin coming from, any ideas?.
Old May 19, 2021 | 04:34 PM
Just Strokin's Avatar
Just Strokin
Isn't tin part of the bearing material used in tri-clad bearings.
ford390gashog's Avatar
ford390gashog
Well phosphorus seems low, I would track the tin for the next few UOA's.
Old May 21, 2021 | 08:55 AM
speakerfritz's Avatar
speakerfritz
I was curious where is tin used in the engine
google say tin ( as part of solder) is used on cooler joints and can leach into fluids
so oil cooler is one place where oil comes in contact with oil.
the info says usually an indication of high acid levels.
I know you have almost 3k on the oil, but me personally would just drain and replace the oil.
cost of oil cooler vs cost of oil makes this a no brainer to me.
there is no acid number in the oil sample result......my guess is if there was....more folks would abandon trying to extend there drain interval and just put the oil sample money towards new oil.
I drive high stop and go so I come under severe duty and rarely does my oil make it to 3k miles.
mountainhoundf350
6.7L Power Stroke Diesel
Dec 4, 2012 01:43 PM
brandon_oma#692
Apr 9, 2009 10:57 PM
cps
Jul 19, 2008 05:19 PM
texas_vet
Feb 20, 2006 10:40 AM
Pirate16
General Automotive Discussion
Nov 2, 2004 06:43 PM
